Replacing Original Traction battery with Nexcell LiFePO
Discussion in 'Gen 2 Prius Technical Discussion' started by JasonMRC, Jan 30, 2023.
  1. dolj
    dolj Senior Member
    8,637
    4,390
    Wellington, New Zealand
    I'm not sure whether you meant this to come across as a negative (pun intended) thing, but a minus value just means current (or Amps) going into the battery. The meter views current going out as a positive and current going in the battery as a minus.
  2. JasonMRC
    JasonMRC Junior Member
    Washington, GA
    Yes, I am aware of that. My statement was referring to the fact that in that image you can see how no significant power was being used (indicated by the flatlined HV Current Amp graph), yet the battery was steadily dropping over just a few seconds (HV SOC graph lowers from 43.6 to 38.5 over 9 seconds).
