Replacing pads and rotors due to wobble
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GerryC11Pr, Jan 7, 2018.
  1. GerryC11Pr
    GerryC11Pr Junior Member
    22
    Southern California and sometimes Mexico
    I've had a wobble upon braking from faster speeds, freeway off ramp or anything over 25-30 mph... I've associated that with warped rotors in the past in other cars.
    So I bought some rotors and pads for front end. After taking the tires off and the position I see plenty of pad left on both sides... If I change the rotor should I also change the pads or leave them be and return the new ones?
    I've attached images of both sides.
    The boots to the struts have broken up and flopping.
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Mileage on her?
    Innmy opinion, you still got some thickness left on both the discs and the pads.
    The problem could be a terrible buildup of rust on the contact surface on the rotor discs might be what's causing the wobbles.
    If its possible, get emery cloth, and sand paper them, or if you want replace them all. New discs and pads.
    It could also be the bearings in the hub assembly that is about to fail, or the wheels not properly tightened.
    Raytheeagle likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I would check the runout on the rotors before replacing them. As @Dxta said, there may be another cause.
    The boots on my wife's '07 have been shredded for a long, long time and the rods are still pristine looking. I don't think I'd go the the bother unless I was in a salty or muddy environment and the struts were new enough to make them worth the effort of putting new boots on without replacing struts along with the boots.
  4. GerryC11Pr
    22
    154k
    Going to replace the rotors n see how it goes
  5. jerrymildred
    11,517
    14,164
    Tampa, FL
    Since you already have them, go for it! (y) But it does seem odd that it would need even new pads, much less rotors, with so few miles. Unless a brake piston got stuck and overheated a rotor.
  6. GerryC11Pr
    22
    Yeah...was thinking same... This next image is from the right side pads... Is the red grease stain from stock... Or could be replaced before?
  7. GerryC11Pr
    22
    Well no more wobble nor any squeaking at all. Seems to be all good... Guess I'll return the new pads... Still plenty left on others.
    Thanks for all suggestions.
    jerrymildred and Raytheeagle like this.
  8. bisco
    52,773
    congrats! you don't waste any time.(y)
  9. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    You got to drop a bottle of French, or American beer to bisco then.
    Hey, bisco, how you doing!?:D
