Replacing PRIUS 4 Buttons MFD SCREEN 86110-47260 with 7 Buttons
Discussion in 'Gen 2 Prius Technical Discussion' started by Ged, Aug 16, 2017.
  1. Ged
    Ged New Member
    United Kingdom
    ----UK----
    My Multi Function Display screen in the middle is not responding. Please advise if I could upgrade my 4 Button Multi Function Display (MFD) 86110-47081 in Prius T3 with the 7 Button MFD 86110-47260 2008?
    I would like to connect with original GPS Toyota Prius DVD device and rear view camera. I have found that my MFD is connected with 3 connections at the back (not 4).
    Is this “mission impossible” ?
    Thanks in advance for the help.
    49,665
    there was just another thread here on this. i think the answer was no, but uk may be different.
  3. Ged
    Ged New Member
    United Kingdom
    ----UK----
    Thanks, I would be glad to find that thread. Was that last month? Maybe there is more detailed info.
    49,665
    no just recently. try some different words in the search function, i will as well. i think the poster was fredsimm?
  5. bisco
    49,665
    found it, '2009 mfd constant reboot'. but he was hoping to replace a bad 7 with a 4. no go. i don't know if it would work the opposite way, but you can call todd at @TampaPrius.com as fred did, for expert info.
  6. Ged
    Ged New Member
    United Kingdom
    ----UK----
    No, I have now with 4 (with a faulty touchscreen) and considering to replace with 7 Buttons ( to install back cam and SAT NAV)
  7. bisco
    49,665
    exactly
  8. Ged
    Ged New Member
    United Kingdom
    ----UK----
    Thanks
  9. dolj
    dolj Senior Member
    7,737
    3,917
    Wellington, New Zealand
    I do not believe the 4-button and 7-button MFD units are compatible.
    In addition, adding the GPS and back-up camera are not a simple remove and replace operation, as the non-GPS model does not have the necessary wiring looms, so they all need to be procured and then installed. In addition you need to procure the additional hardware to install the GPS and back-up camera.
    I've never heard it reported that anyone that was thinking of doing this has gone ahead and done it.
    If you really want these features, look out for a nice T-Spirit and trade your current car for that one.
    Ged likes this.
  10. Ged
    Ged New Member
    United Kingdom
    ----UK----
    Good advice :)
  11. ih8spm
    ih8spm Junior Member
    73
    29
    New York
    Why not just add a back camera and use a phone as GPS? Both are cheaper and easier although not as stealthy but way more accurate. I recently purchased a back up camera with LED for night mode on Amazon for 19.99 during a flash sale. It screws over the license plate upper bolts and gets a positive trigger for power from the reverse light bulb positive. Run the cable in and down the side to the front and clip the new mirrow over the old one assuming you don't have homelink they don't fit over those.
    SM-G935P ?
    Priusdriver06 likes this.
