Replacing Radiator on 2015 Prius C
Discussion in 'Prius c Technical Discussion' started by Fastfret7, Aug 22, 2019.
Tags:
  1. Fastfret7
    Fastfret7 Junior Member
    24
    Virginia
    2015 Prius c
    Other than obvious steps: like draining coolant, taking off the bumper, and front frame, is there anything special I need to do? Is there special steps for draining and replacing coolant?
    I got that one 1 piece Denso radiator 221-9302 that is suppose to have the inverter/engine sections.
    Tips would be great.
    Thanks,
  2. DonutRobot
    DonutRobot Junior Member
    Ohio
    Perhaps you're the first Fastfret7! Good luck! Let us know how it goes.
  3. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Any updates?
  4. ilker_t
    ilker_t New Member
    usa
    Anyone has any experience changing the radiator on Prius C?
    Did you manage to change the radiator yourself? Front bumper removal is necessary on Prius C?
    #4 ilker_t, Sep 17, 2023
  5. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    Yeah you need to remove the front bumper, what i'm not sure is if that you also need to remove the A/C lines, i hope not.
  6. ilker_t
    ilker_t New Member
    usa
    I know you have to remove the front bumper for Prius, but are you sure thats also the case for Prius C?
  7. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    UPDATE: This is false, the front bumper does not needs to be removed to replace the radiator.
  8. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    I was wrong. There is no need to remove the front bumper in the Prius C in order to remove the radiator.
