Replacing rear caliper bracket without the caliper
Discussion in 'Gen 3 Prius Main Forum' started by tonymats, Sep 16, 2022.
  1. tonymats
    tonymats Junior Member
    New York NY
    I am replacing rear brakes on my 2013 Prius Two and came across a stuck caliper pin. The simplest thing to do is to buy a new caliper bracket, but it appears they are not sold separately from the calipers (at least not for my car). So I want to buy a cheap set on ebay, use the bracket and discard/return the caliper.
    My question is - are there potential compatibility issues if the bracket is from a different manufacturer than the caliper? It's not clear to me what the current caliper brand is and I definitely don't feel right replacing the caliper and bleeding the brakes - that's way above my skill level.
    Any advice would be much appreciated!
  2. Mendel Leisk
    42,376
  3. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    You should be able to unscrew the pins from the caliper bracket and buy a pin and rubber kit it'll be the slide pins and the rubber bushings and probably a pack of grease might want to get upgraded grease I just like $9 a caliper or something or bracket pretty inexpensive or you can even tap them off with the hammer the calipers that is get your Dremel out with the wire wheel what have you and you can buff them right back up to clean I've even buffed pitted ones that were really bad before you could buy these pins clean them up grease them up clean out the rubber and the piece that fits into and regrease and put it all back together I don't put it together until I can move the slide across the pins with my pinky finger if it doesn't move that easily I clean it and redo it again until I have it where I can push it with my little finger and that slide goes all the way out and pulls all the way back with my small finger then I know it's going to stay on there another hundred thousand without sticking generally speaking
  4. ChapmanF
    19,056
    One saving grace, the bracket is symmetrical, same part number for left and right. A person wanting a spare on hand in case an old one got too rusted up would only need one spare.
    Not so for the fronts; those have left and right brackets.
  5. Mendel Leisk
    42,376
    Puzzling: the bracket costs over $25 USD more than the caliper. Vagaries of supply and demand I guess. And the "lifetime" brakes mindset.
  6. Tombukt2
    13,875
    2,521
    Durham NC
    Probably expensive because the pins and rubbers are available and most people probably buy those in the fast moving part section rather than buy the whole slide or bracket or whatever you want to call it if I'm not mistaken I haven't personally looked up the Prius but my Corolla and Camry have replaceable pins or slide pins or whatever you like to call them.
  7. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    What do you mean by "stuck"?
    It won't turn so you can remove it?
    Or you can get it out after loosening it.
    The simplist was is not really to replace the whole thing.....
    It would be to figure out why it is not "removing" and then remove it, if possible.
    Then remove the boot and clean both and lube them.
  8. Siward
    Siward Active Member
    314
    128
    Toronto
    Wow. I had this same question about 3 years ago. I was constantly getting uneven brake pad wear on my rear brakes, so I wanted to replace the brake caliper bracket in hopes the pads would wear evenly. I changed everything from the caliper lube, to the brake hardware and even the caliper pins/boots and grommet at the bottom of the pin. I eventually decided it was worth replacing the caliper bracket.
    Well, I did find the brake bracket sold separately at the dealership in Canada. The problem is that the dealership bracket price was greater than paying for the complete replacement with an aftermarket caliper. The price of the OEM complete caliper assembly at the dealership was just ridiculous. I can't remember what price it was but it was about $300-500. I hope you find a better price.
    I ended up buying a whole Raybestos caliper assembly from RockAuto. I got it installed by a mechanic for a cheap $60. It has been working well for the past 3 years (but with minimal driving during COVID19). It worked for me, but it didn't work another poster in Montreal, Canada:
    2012 Prius - New Calipers, Pads Still Dragging (hot brake discs) | PriusChat
    I also lost a set of brake pads due to a stuck caliper pin. It was heavily rusted in there. I managed to wrestle it out of there by twisting and pulling until the scraps of rust came out. I sanded all the rust out and replaced the pin. Maybe yours is stuck in there forever. Yes. This is the same caliper I replaced in the end.
    #8 Siward, Sep 19, 2022
  9. ChapmanF
    19,056
  10. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
    When I had a stuck pin that ultimately sheared off in the bracket I drilled out the bore and bought a new pin.
    Tombukt2 likes this.
  11. OptimusPriustus
    OptimusPriustus Active Member
    338
    144
    Finland
    Your post (aftermarket caliper) is a rare one. I once read or heard about the gasket acting as spring and i bought it right away. Made sense. But try to explain to someone..or find from chatboardso_O Interesting that Toyota explains it thoroughly in shop manual.
    Kind of same as trying to explain someone that a bolt joint is about friction and bolt is just a spring creating the friction
  12. ChapmanF
    19,056
    If I remember right, that illustration isn't from the repair manual, but from one of the "University of Toyota" technician training modules on disc brakes. All of those materials are also on TIS, same place you find the repair manuals.
    Toyota Service Information and Where To Find It | PriusChat
    A lot of good information available there.
