Replacing Rear Seat Belts - Any Suggestion?
Discussion in 'Gen 2 Prius Main Forum' started by johnjohn15, Dec 17, 2017.
  1. johnjohn15
    johnjohn15 Junior Member
    Southern California
    My 06 Prius rear seat belts (left and right passenger side; not middle) are being chewed up by a dog
    IMG_0001.JPG IMG_0001.JPG .
    Since my wife and I are expecting our first child within a couple of week, we believe we need to replace the seat belts ASAP for safety reason at the junkyard instead of buying them at the dealer.
    So what do you think? Any advice or suggestion is greatly appreciated.
    iPhone ?
  2. JC91006
    16,936
    8,647
    They look like they'll hold a car seat. I may have a driver's side available for sale. Not hard to install.
    I think mine is gray.
  3. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Steve at autobeyours.com has a lot of Prius parts.
  4. johnjohn15
    Southern California
    I have purchased used ones at the junkyard. They're in great shape.
    Do you know OR have any DIY info on replacing the seat belts? I am mechanically inclined to do this but do not know where to start
    iPhone ?
    ScottHz likes this.
  5. JC91006
    16,936
    8,647
    You have to disassemble the back end of the car, remove the side panels and then there's a 14mm bolt holding the seat belts.
    You can watch videos on YouTube of hv battery replacement. It shows how to disassemble the back end. It's fairly simple. If you have a 10mm impact wrench, it'll be done in 20 minutes
    ScottHz likes this.
  6. johnjohn15
    Southern California
    Alright. And are the side panels really that delicate to break? The seller from the junk yard advised me to carefully remove the side panels or these will break so I'm not sure if it true?
    iPhone ?
    ScottHz likes this.
  7. JC91006
    16,936
    8,647
    No, side panels are not easy to break. Not sure how you can break them unless you don't disassemble the back end correctly.
    Watch the YouTube videos on hv battery replacement. It's a piece of cake
    johnjohn15 likes this.
  8. dawnrek
    dawnrek New Member
    Washington DC
    JC
    My Prius is 2007 and I intend to replace the rear seat belts (also a bit chewed). Do I need to disconnect the battery before disassemble the back part as seen in the “hv battery replacement” video you suggested?
    I don’t have any SRS there so I would expect no. Any advice?
    Thanks
    QUOTE="JC91006, post: 2650005, member: 119012"]No, side panels are not easy to break. Not sure how you can break them unless you don't disassemble the back end correctly.
    Watch the YouTube videos on hv battery replacement. It's a piece of cake[/QUOTE]
    ScottHz likes this.
  9. daninewyork
    daninewyork New Member
    Amsterdam
    Business Edition
    And did you disconnect the battery before dissambling? Because I have exactly the same problem and this could be very helpfull.
    Thanks
    [/QUOTE]
  10. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    I sure wish someone would do a video of this... I've got two seat belts eaten by dogs to replace. Off to google the battery replacement videos.
  11. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    2010 virtually the same. Seat belt manual attached.
    #11 alftoy, Jul 10, 2023
    ScottHz and PriusPaddler like this.
  12. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    Video is for front seats.
  13. highmilesgarage
    highmilesgarage Active Member
    494
    185
    Kansas City
    they are extremely easy and you don't need a youtube video for that :) I think it can even be done blindfolded and you don't need to disconnect anything (battery or HV). The side panels (and other panels) are easy to remove and this is where you mostly spend most of the time disassembling.
    They are very strong despite being chewed, it takes a razor knife to cut it. Unless you're driving at 200+ mph and the baby weighs a ton it could snap. There are seatbelt covers that can hide that cosmetic issue.
    ScottHz likes this.
