Replacing the AC EVAPORATOR? Mold / Smell in the AC System
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by andreimontreal, Oct 9, 2019.
  1. andreimontreal
    andreimontreal Active Member
    325
    107
    28
    Montreal
    I did the spray procedure back in March 3 times back to back. I bought the car from a dealer, he pumped a crap load of air freshener inside that my lungs were burning after 3-4 h in the car (well you know what I mean), after a few days, weeks it wore off, and I started to feel the moldy stench .
    I cleand once with Nextzett, and twice with this. I inserted the pipe from the evacuation running at the feet in front of the passenger seat at the end of the carpet; from all the research I understood that the evaporator is there in the cabin. The first two times the water was really murky and only the 3rd time it was clean enough that it looked white like the foam. Toyota has a kit - check these instructions.
    The smell after that was ok. It smelled like an old fridge, like plastic and cold air. The past few days I felt a hint of bad smell - very faint, nothing to worry - but I don't like the air quality overall. I have this 2008 Civic that has better air and it's dirty like a pigsty. I want to deal with this once and for all (meaning for the next 10 years, I don't wanna smell moldy air again).
    I've seen a bunch of people opening their ac systems and the condenser coils were really dirty and moldy. I bet mine has some residues that keep on growing. Or not? Let me know if you have any experience.
    What's the average cost of replacing that part? Is it a complicated thing? Aside from the fact that the freon would need to be captured, I bet it's a simple plumbing type of situation, right? It's just about disconnecting it from the AC system and connecting the new one in with the appropriate thread sealer?
    Somebody give me ideas. Something smart like pouring gasoline down the ac system and lighting it all up.
    #1 andreimontreal, Oct 9, 2019
    Krsna likes this.
  2. Elektroingenieur
    2,515
    3,253
    Three Touring
    Recovering the refrigerant (R-134a, not Freon 12, by the way) is the easy part. The evaporator is part of the air conditioning unit assembly, and as the Repair Manual (more info) explains, to get to it, you have to take apart the entire instrument panel. Toyota’s Flat Rate Manual allows 6.1 labor hours for removal and replacement.
    Toyota’s service bulletin, T-SB-0143-13, “HVAC Odor Maintenance” (PDF), revised November 10, 2016, has some suggestions, besides their cleaning kit. You could try to make a habit of switching to the fresh air mode when parking, and replace the cabin air filter with a charcoal-impregnated one, part number 87139-50100.
    Perhaps @lech auto air conditionin would be kind enough to share some suggestions, too.
    Robert Holt likes this.
  3. ASRDogman
    ASRDogman Senior Member
    5,908
    3,167
    One way we cleaned the evaporator in Mercedes was to close the windows, put the a/c on recirculate,
    fan on high and spray a full can of lysol into the air intake inside the car then let the car run about 10 minutes.
    Make sure to hold your breath when spraying!
    Robert Holt and RMB like this.
  4. Leadfoot J. McCoalroller
    6,840
    6,484
    Pennsylvania
    2018 Prius c
    Are you sure you’re smelling the evaporator? Could be the carpet, pond in the 12v battery well, spare tire well etc…
    Replacing the evaporator is ridiculously labor-intensive on most cars, the Prius is no exception.
  5. andreimontreal
    325
    107
    28
    Montreal
    Yes refrigerant. How would one go about collecting that? I saw an instrument panel disassembly at some point - since it's something I can do, that's the easy part for me :) . Yeah, I know it should take hours, a lot of parts in there - it takes a lot of organization and pics to keep track of everything.
    Not my cup of tea - I have an issue with chemical cleaners and whatnot; especially air fresheners. I used that chemical foam spray but after that I made a mix of orange oil, home made vinegar and water, and I sprayed from the outside. I got this trick from another forum, where they got rid of the smells but the issues return eventually - I think - in my case it seems so. So that's why I want to dive in. I will be travelling in this car, I wanna get hands down, up close and personal with every inch of it.
    I would say so, yes. I mostly feel that smell when the AC is on, and it's strong (relatively strong, enough that I feel it, that's what I mean) at first then lessens.
    Even if labor intensive. I'm willing to spend 2-3 days on it. I'd love to take a look inside to see what's up and to clean everything spotless. I've done elaborate mechanical work before - it doesn't scare me one bit. Been fixing our cars with my dad (mostly mechanical, no engine work); been fixing a whole lot of things since I was young - so tons of screws and parts that fit with a design is not an issue. I have an air compressor, air tools. Recently I took out panels - I'm converting the car into a solo mini travel camper so I've already warmed up for panel removal. As for endurance: bring it on.
    I heard before that Toyota (and a bunch of other brands) had issues with their evaporators developing mold (heard there were class action lawsuits because of this issue). Is there a part that I can buy that's better than the OEM? Anything I can do mechanically to ensure this issues doesn't happen again?
    I'm not sure how to deal with the refrigerant though. Looking at this clip, it looks like more shit to buy and I just don't wanna ... I found another guy who uses a spray can to fill the ac system - but this means I'd have to let the first batch evaporate, get out - right?
    I see that R134a is considered harmful for the environment. If I have to let it go, could I - at least - refill with the option mentioned there? I'm not that hvac savvy.
    #5 andreimontreal, Oct 10, 2019
  6. ChapmanF
    15,110
    Well, that's why it's to be recovered using suitable equipment. If you don't want to buy expensive equipment for one job, well, that's kind of a thing A/C shops do.
    You could have a shop evacuate the system for you, drive it home, do the hours and hours of instrument panel R&R yourself, and go back to the shop when you're done for evacuation and recharge. I went that route with another vehicle, it was pretty painless.
    You don't have to, and, seriously, don't.
    Old Ford Ranger / Bronco II for the win. HVAC case was two shells, one either side of the firewall. Evaporator in the engine compartment side. If you had a helper, you could unbolt the compressor, condenser, and evaporator, and lift the whole A/C right out of the truck unopened (I was doing an engine rebuild) and put it right back in afterward.
    Had to first push the engine wire harness grommet through the firewall (the wiring went 'through' the loop of A/C hoses) but that was about the only prep needed.
  7. Leadfoot J. McCoalroller
    6,840
    6,484
    Pennsylvania
    2018 Prius c
    I never dealt with one of those, but a lot of them were easier in the days when AC was still available as a dealer-installed option.
  8. andreimontreal
    325
    107
    28
    Montreal
    Awesome! I was wondering if that was an option.
    Ok, let's see if I'm gonna do this now or after this winter. I wanted to try tea tree oil with water - sprayed though the air intake like the "phase 2" for the usual treatment. That should kill mold and leave, at least for a while, a minty fragrance.
    If any of you stumble upon videos, or have recorded something yourself, feel free to add to the thread. Or if you find car plans in pdf format. I'll go to my library to see if I have access to Chilton stuff.
  9. Leadfoot J. McCoalroller
    6,840
    6,484
    Pennsylvania
    2018 Prius c
    Eh, just throw yourself down a flight of stairs and it’ll be less painful than getting useful Prius info from Chilton’s.
    The real stuff is on Toyota’s tech info website. Not free, but cheap enough and the manual available there is fantastic. You can use your access to save portions of it for later reference.
  10. Elektroingenieur
    2,515
    3,253
    Three Touring
    The Chilton books may be too thin to be useful, but the ChiltonLibrary online database (mentioned on the PriusChat Wiki page) includes the text and illustrations from Toyota’s Repair Manual for the 2012 Prius, plus most of the pages from the Electrical Wiring Diagram. The formatting and organization could be better, but if your local public library subscribes, it’s a no-cost option.
  11. lech auto air conditionin
    830
    601
    260
    san francisco
    you can attempt to try some of the cheaper alternatives using sprays is the easiest do it yourself method. sometimes it works for months occasionally it works for years. but that also depends where you live and what kind of mold spores are in the air what kind of plant material is in the air , dead leaves and grass.
    Different parts of the Country and different automotive distributors carry different products.
    You are definitely looking for one that specifically says it’s a anti-bacteria or anti-fungicide. Some of the kits even give you a second aerosol spray canister that is nothing more than a perfume to cover up the smell I personally and many other people cannot stand the overbearing strong smell of some of these fragrances.
    You must read all the instructions entirely for it to work effectively. The majority of the products want to be sprayed on a dry evaporator so that means your air conditioning must have not been in use recently to condensate water on the fins and coil. By opening up your glove box and removing the air filter turn on your fan in spray on the inlet of the fan keep your face out of line of sight of where the air is discharging out of the ducts.
    Some instructions will tell you to keep the fans running either instructions may tell you to turn the fans off. Then the instructions will give you some sort of set time to wait to allow the chemical to dry into a film that stays attached Coating in the fins. In the meantime do not turn on your air conditioning or defogger. Because this will cause your evaporator to get cold and instantly start making water that will wash off the chemical.
    And be careful some of the recommendations of home do it yourself products are corrosive on aluminum with the additives in some of the homebrewed bathroom type aerosols. It will not do immediate damage it’s something that happens over a long period of time and replacing a leaky evaporator on a Prius is not a cheap job.
    I also forgot to mention in some cases depending what your contaminant is dust or spores from trees use one of those expensive really tightly pleaded dense filters to reduce the amount of small particulate matter the only problem with those fine filters they plug up really fast and start restricting airflow. Depending on how dusty your environment is I would recommend pulling it once a month and blowing it out with Shop air in reverse airflow order so it does not create a restriction any little restriction of airflow reduces cooling performance.
    #11 lech auto air conditionin, Oct 14, 2019
  12. lech auto air conditionin
    830
    601
    260
    san francisco
    The only problem with spraying a mist of oil bearing products oil stay sticky and tacky and collect dust that will build up and restrict airflow in between the fins.
    Fine particles of dust love collecting and sticking to oil it acts like a filter.
    Oil work so good as a filter back in the old days on cars before they had mechanical paper element filters they had something called an oil bath where your air filter was nothing but a channel that air ran down through a groove to a large puddle of oil in the bottom of the air filter channel and then back up before entering the engine.
  13. ASRDogman
    5,908
    3,167
    If the man wants to remove or disassemble the whole car to clean the evaporator, let him do it.
    It's his car. Perhaps he likes doing things the hard way. :rolleyes:
    Several people have given him very good ways of cleaning it.
    Let him decide on how he wants to do it.
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    And additional food for thought:
    The smell can be caused by "stuff" growing in the drain pan due to poor drainage.
    It also can be due to "stuff" building up in the air intake, usually between the back of the hood and the bottom of the windshield.
    You should check those two things first.
    A really competent A/C place would tell you that.......or offer to do it for you for a few $$$.
  15. ASRDogman
    5,908
    3,167
    You're telling the wrong person.... I already know this.....
    My a/c doesn't smell... (y)
  16. sam spade 2
    7,035
    2,783
    2017 Prius c
    My comments really weren't directed at YOU.
    Did you really NOT understand that ??
  17. Mendel Leisk
    38,253
    The Achilles heel of most-if-not-all AC systems, is if you use them constantly, right up to the point you shut the car down, you've created an ideal environment for mold to grow. A couple of mitigating tactics:
    1. Just don't use the AC so much. Run the fan without AC, and/or crack the window down a bit and shut it right off.
    2. When you do use AC, try to remember to shut it off at least a mile before your destination, and keep the fan running at moderate speed, to blow out the humidity.
  18. sam spade 2
    7,035
    2,783
    2017 Prius c
    One more thought:
    If.....you car sits in a garage or under a roof most of the time, that is the ideal environment for mold growth in the summer.
    Mold doesn't like REALLY hot nor really cold.
    One of the "spray can" treatments sometimes works a lot better if you combine it with sitting out in the bright sun for a day or two......in the summer, that is. When you first notice it, running the heater for a bit can help too.
  19. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    A coarse filter on the air intake under the hood will help after you get things clean (will also keep mice out).
    I second the idea that tea tree oil will eventually do more harm than good. Since you don't want to use sprays, I'm going to recommend the periodic use of an ozone generator. It's frequently used on boats to reduce/eliminate mildew, and works really well in enclosed spaces. Do not EVER use it while you are in the car, and let the ozone dissipate before you get in it again.
    Use it overnight, or even better, over 24 hours or more.
  20. andreimontreal
    325
    107
    28
    Montreal
    I'll keep this in mind. It's a tiny amount of essential oil, more volatile than regular oil, and water. I've already sprayed vinegar infused with orange peel (aka got its fresh oils in, those were ripe and fresh straight from the deposit) and water (1:1 ratio with the vinegar I think) right after I did the foam clean, sprayed on the mist setting at the air intake outside of the car. When I'll open the ducts, I'll check for buildups - I think I know what you mean, I've seen them in various mechanical devices, like sewing machines for e.g..
    Lol yeah. Sometimes. Just to see if it's worth it. If it's a mistake still makes me better after all - so win win either way.
    This is exactly what I've been (theoretically) cleaning with the foam spray - the thing I say I did 3 times. But you never know what's exactly inside there, and if it takes some scrubbing - well that foam ain't no fairy miracle working product. I've seen this guy's old evap on this forum, and it had all sorts of stuff in it: tree stuff, tons of mold, etc etc - he said he'd even found a dead mouse over the time. Mechanic's stories ...
    That's why I wanna tear it apart. I wanna check it A to Z and to learn it - in case I wanna mod something.
    _________________
    For those wondering why I'd plunge in my self. I'm modding this car for travel - so, the more I know about anything in its system the better. And even if I wasn't doing the project, I'm the kind of guy that gets hands on and personal with his objects. I've repaired a lot of my stuff - from laptops to clothing. The more I do, the easier it gets to learn a new skill, the more I know, the less fear I have about doing it. I work in cinema, my schedule is flexible, so I'm not your average 9 to 5 guy. I'm an avid DYIer. For photography I've done some custom gear - I could have bought it, I had the money for it (and I've spent a lot on stuff I barely used) but sometimes it's not about buying it; now that I've done it, I feel confident about building something custom and that's priceless .... it's freedom, old school I might add.
