Replacing the AC EVAPORATOR? Mold / Smell in the AC System
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by andreimontreal, Oct 9, 2019.
  1. Mendel Leisk
    41,451
    You REALLY have to gut the dash to get to the AC unit. There's pics: it looks like a bomb went off.
    Krsna and Raytheeagle like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    :ROFLMAO::LOL::ROFLMAO::LOL:
    It’s involved that’s for sure ;).
    It gives you a new perspective on how things are put together(y).
  3. andreimontreal
    andreimontreal Active Member
    378
    114
    32
    Montreal
    Yeah, I saw that in a time-lapse of a mechanic ;) - thanks for the heads up.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,802
    2017 Prius c
    But.....have you actually looked at the drain point while running the A/C to see if water is actually coming out ?
    You usually do not have to "tear anything apart" to improve either the drainage (suck on the hose with a shop vac) or to inspect and clean the air inlet for the HVAC system. The air inlet might require some minor dis-assembly.
    But it sounds like this is another case of "My mind is already made up......." so I wish you luck.
    There is a HIGH potential for damaging other things if you really do take the evap out.
  5. Shaybh
    Shaybh New Member
    Israel
    2016 Nissan LEAF
    Would love to hear if you eventually replaced the evaporator, and if it solved the issue? I have the same problem, did all the sprays from different angles. Now at the point of deciding whether to replace the evaporator or sell the car...
