Replacing the hybrid battery with a new Toyota battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Deadbeat, Sep 6, 2017.
  1. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Don’t use a ft-lb Torque wrench to tighten in-lb bolts. Generally ft-lb Torque wrenches are not very accurate at the lowest settings. I wouldn’t even trust my 3/8 inch torque wrench for inch pounds, and I use that for the lower foot pound range.
  2. Mendel Leisk
    41,479
    Yup. 1/4 torque wrenches, usually scaled around 20~200 inch/pounds, are the way to go. You may need 1/4" to 3/8" socket adapter too.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Here's what Snap-On has to say about it. In the nuclear industry, torque wrenches aren't used at the ends of their range (I recall 25% from each end is the limit)
    https://www.snapon.com/V2/Groups/cmsINDUKau/PDF/PDFUK/Torque_Brochure.pdf
  4. Mendel Leisk
    41,479
    Sears salesman told me similar.
    Raytheeagle likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    What’s Sears:p.
    johnjohnchu and Mendel Leisk like this.
  6. Mendel Leisk
    41,479
    It's just a dark star in our local mall right now, nobody's even moved in. The last few years it was in operation it started to look very disheveled. I recall going in for vacuum bags, that we'd purchased there before: they didn't have a vacuum department anymore, had just a few a few odds-and-ends, and a salesman told me to just order them on Amazon. Which I did. :(
  7. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    They still have a mail order where you can get these things. I ordered some replacement blades for a Handi-Cut last week.
  8. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Our local mall one has been vacant for about a year or so and is going to be converted to a Dave and Busters:cool:.
    Nothing like an Adult gaming place in a mall(y).
  9. HT12
    HT12 New Member
    Oregon
    Amazing–thanks so much for this!
  10. JayMikey
    JayMikey New Member
    Ohio
    Sorry...I know this is a really old thread. When you mention disconnecting the 12v when doing this work, is it sufficient to just unplug the 2 plastic cable connectors from the positive terminal? Should the negative connection and the connector at the control box also be removed? Thanks for all of your explanations and insight about performing this job.
  11. Mendel Leisk
    41,479
    My 2 brain cells never fully grokked the reasoning, but I've always heard disconnecting the the negative connection is safest.
  12. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    People get lazy and do that. In theory it doesn’t matter. But shite happens, and it is for good reason it is BEST to always disconnect NEGATIVE first, then positive. Do the reverse when installing: positive first, negative last.
    Here is why from the beloved Car Talk brothers Click-and-Klack
    RAY: You're using a metal wrench to disconnect the battery cables. If your wrench contacts a piece of metal that's connected to the frame, you've got a short circuit, because all the ground circuits are connected to the frame, and the negative terminal of the battery is connected to the frame.
    If you disconnect the positive terminal first and touch the wrench to a metal ground on the car, it’s tantamount to laying your wrench across the two terminals of the battery. So the reason that you disconnect the negative first is, if in the process of loosening the bolt to remove the negative terminal, the wrench should contact the frame, it doesn't make any difference. Because the negative terminal is already connected to the frame. And that's why when you go to put the battery back in, you reverse the order. You connect the positive first and then you connect the negative last.
    Another and Mendel Leisk like this.
  13. Bucci
    Bucci Junior Member
    New Milford, CT
    Hello I know this is an old thread but did anyone come up with a video for migrating old battery parts to a new toyota hybrid battery?
    Thanks,
    Paul
  14. ericbecky
    ericbecky Hybrid Battery Hero
    4,440
    3,308
    Madison, Wisconsin
  15. 4priusowner
    4priusowner Junior Member
    69
    You know I m sorry got caught up in other things and haven't edited yet the video but maybe I will just upload in steps without editing.
  16. Randy Castleman
    Randy Castleman New Member
    Moreno Valley
    Four Touring
    Again reviving an old thread. I'm getting ready to install a new Toyota HV battery in the daughters 08, any known step by step instructions or videos on performing the swap?
  17. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Amazon, the new Sears except Sears, in its heyday, used to source most of its products from USA manufacturers. Sad.
  18. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    This video is good, but I still used hv gloves and tested the connections before I touched the key points. Also it’s a little different since they’re swapping modules and not entire new battery. there are three bolts under the relays that separate the relay case from the module case.
    #38 Ds001001, Dec 9, 2021
  19. Randy Castleman
    Moreno Valley
    Four Touring
    Thanks Ds001001, I think I got it stripped down and ready for a core return after I get the new battery up and working.
