Replacing the license plate bulb
Discussion in 'Gen 2 Prius Main Forum' started by Whiteyprius, Oct 23, 2014.
  1. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    I am aware that you get to the license plate bulb from the inside through the hatch - Instructions I've read say "Remove plastic panel inside hatch." OK, but how? I don't want to simply randomly pry around, not knowing just where the tabs are. Can anyone help? Pix would be great! We're talking a 2008. Thx!
  2. Patrick Wong
    18,200
    6,479
    Without using any tools, grab one corner of the hatch panel and exert force to pull it away. Once you get a corner loose then you'll find it is easy to remove that trim panel.
    Merkey likes this.
  3. JC91006
    16,489
    8,402
    There are 11 tabs that go around the panel. Like in a rectangular evenly laid out format.
  4. Tideland Prius
    16,172
    Unfortunately, it really is the entire back panel that has to be removed (they fixed this issue with the Gen 3 by providing little cutouts).
    A flatblade screwdriver can help you if you're not comfortable with exerting a lot of force on the plastic panel. Just be aware that the panel is pliable so be careful with the screwdriver. I usually start with the corners where the panel comes up the sides to meet the lower rear window, just prying it out a little, then go towards the centre where the latch hook is and pry that out a bit (A bit of an analogy is like prying up those old school metal lids on a tin can where you just use a flatblade to lift up the metal lid and you keep going around until the lid pops off). Hopefully it'll make it easier to pull off once you have a gap around.
