Replacing the (useless) fog lights with (useful) driving lights?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mkarolian, Aug 26, 2013.
  1. mkarolian
    mkarolian Junior Member
    56
    Boston, MA
    I was hoping to replace the fog lights that are currently in our '08 touring with these well-reviewed driving lights I found on Amazon.
    Has anyone done a similar swap? I was hoping that I could simply use the existing wiring, but I am unsure how much of a difference there is in how much current they draw and I don't want to overload a wire (is that a thing?) or blow through fuses.
    Any insight would be very much appreciated!
  2. xliderider
    xliderider Senior Member
    7,873
    3,116
    Honolulu, HI
    I swapped my OEM reflector foglights for some projectors. Link is in my signature below.
    If you're concerned about blowing fuses and melting wiring, use the wiring harness and relay in the kit to connect to an appropriate power source.
    SCH-I535
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
