Replacing transmission oil
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, May 21, 2017.
  1. franken1313
    franken1313 Member
    216
    27
    US
    I can easily get a socket wrench just fine .
  2. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Inferring from you last two posts, are looking you for a power tool that's the size of a socket wrench?
    Just get a breaker bar and the job will be done. Or a length of pipe over your ratchet if you don't like the ratchet that much.
  3. TerryM
    TerryM Member
    46
    44
    West Central Illinois
    http://techno-fandom.org/~hobbit/cars/maint50k/nakedunder.jpg
    As stated earlier, There are transaxle coolant and transmission fluid fill and drain bolts in same area. Look at the picture in this link. Make sure that you are trying to remove the plugs marked by the green arrows. PLEASE listen to everyone else that has told you NOT to use a torque wrench to remove any stuck bolt. They are not made for removal but for precise tightening of fasteners. If you do not have a breaker bar, a rachet wrench may work in a pinch. The best thing to do if you do not have a breaker bar is to rent one from your nearest national autoparts store. Autozone, O'reilly's, and Advanced Auto all have tool rental available for next to nothing. Please be kind to your expensive tools and they will last for a long time. Abuse them and they will break the bank in replacement costs.
    jerrymildred likes this.
  4. Mendel Leisk
    42,277
  5. franken1313
    franken1313 Member
    216
    27
    US
    Ok I will get a breaker bar.
    Any recommendations?
    Raytheeagle likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    (y) If you don't use it often, I'd go cheap and get one at Harbor Freight if there's one nearby. I recommend 1/2" drive for maximum strength without getting too big to handle common socket sizes.
    Or, as some said, you can rent one really cheap.
  7. franken1313
    franken1313 Member
    216
    27
    US
    I'd rather buy it . I plan on changing the fluid myself from now on
    #27 franken1313, May 22, 2017
  8. franken1313
    franken1313 Member
    216
    27
    US
  9. Mendel Leisk
    42,277
    I went with the above Jet wrench (post #24), 1/2" drive, ratcheting, swivel head, eventually. It was indespensible for removing an engine block coolant drain bolt on a Honda. Probably about $60, but well worth it. For a number of years I made do with a cheapie 3/8" made-in-China one from Princess Auto, around $20. I also found a long handled ratcheting crescent wrench (19 and 17 mm) indespensible, for a PCV valve removal recently. Bottom line, you can never have enough wrenches.
    Looks good, good reviews. I tried to compare to Jet, didn't see it on Amazon. Check local stores too, smaller automotive stores in particular, they tend to have more hands-on expertise, knowledge.
    A 1/2" to 3/8" adapter is good to have too: often your sockets are 3/8", and the breaker bar 1/2". There's one on the 1/2" torque wrench, top of my pic. And an assortment of extensions, and, and...
    Full disclosure: I'm guilty of using a torque wrench once or twice to loosen nuts/bolts, years back. :oops:
    #29 Mendel Leisk, May 22, 2017
  10. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    I went with a cheap one, no Harbor Freight in my area:
  11. jerrymildred
    11,517
    14,164
    Tampa, FL
    My 1/2" breaker bar is a Craftsman that I've used for almost 40 years. The 1/2" drive ratchet is from the same kit.
  12. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    I remember years ago hearing that people would use Craftsman screwdrivers as pry bars, because if they bent it they just took it back to Sears and got a free replacement no questions asked. Guess in those days you could have also used a Craftsman torque wrench as a breaker bar!
  13. jerrymildred
    11,517
    14,164
    Tampa, FL
    True story. Years ago in Ohio, a guy I worked with was trying to reach something up high in the barrel room and was too lazy to get a ladder. He climbed up on a 55 gallon barrel of Petrolatum (think industrial Vaseline) that had a removable lid. The lid scooted sideways and he came down with one leg on the outside of the barrel, but the other one went into the full barrel (which had to hurt), coating his boot, sock, and pant leg with the stuff. He had a big Craftsman screwdriver in his hand and that took the plunge, too.
    He poured himself a big bucket of methyl-ethyl-ketone (MEK) and left his boot and screwdriver in it to soak while he went to change in the locker room. When he came back, he looked in the bucket of MEK and the boot was gone except for the metal shoelace eyelets and the screwdriver handle was gone, too.
    When he took the screwdriver back to sears, the clerk told him the warranty didn't cover chemical abuse and then gave him a new screwdriver anyway.
    Since2002 likes this.
  14. xliderider
    8,140
    3,278
    Honolulu, HI
    I also have one of these, which will fit on standard 1/2 inch sockets, and is an excellent breaker bar because it comes with a telescoping handle to gain extra leverage. Works well on overtightened lugnuts.
    It needs more room to work in though because it doesn't have a pivoting head like a standard breaker bar.
    Also found this one with good reviews, at a lower price:
    #34 xliderider, May 23, 2017
  15. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    That's fine, but you're spending about twice as much as you need to. You can get a better one at Home Depot:
    Husky 1/2 in. Drive 15 in. Breaker Bar-H12BB15 - The Home Depot
    I've worked on LOTS of vehicles. I have a proper set of 1/2" drive tools with ratchets, breaker bars, impact drivers, etc.. But I've used a copper pipe over my Craftsman 3/8" ratchet so many times I can't even keep track. You're not going to break your ratchet loosening this fastener.
