REPORT: 115 Plug-in Priuses fail to crack 50 mpg average in year-long test
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by cwerdna, Jun 18, 2009.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Google has a small fleet of plug-in Priuses. Go to rechargeit.org for more info. I've seen a few of their cars driving around in the SF Bay Area.
  2. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    Thanks. That is encouraging!
  3. burritos
    burritos Senior Member
    4,946
    253
    Thanks for the link. Here's a direct link to the google fleet results: RechargeIT.org
    [​IMG][​IMG][​IMG][​IMG]
    Looks like the drivers at google understand how to benefit from the plug in adaptation. However, it's harder to get a job at Google than it is to get into Harvard, so the average american driver isn't going to be as bright/capable.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That is because Google has the best lunch and recreational system of any company I've ever have the opportunity of mooching off of. Multiple times. :D
  5. Jared
    Jared Member
    209
    Long Island
    "even to programming in a slight creep when you take your foot off the pedal at a stop, and slight braking when you take your foot off the pedal while moving. There is no need for an electric or hybrid car to do this"
    I disagree. The creep allows you to slowly move forward at stoplights when the car ahead move without touching the gas. It gives you more control. It also "holds" the car when stopped on a slight slope so you don't need the brake.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Toyota has been saying exactly what we are seeing. Plug-in benefit varies very widely. It depends on the driver, habits (plug in at night or not?), driving distance, speed and other conditions.
    These numbers are based on the conversion of the Iconic model. The 2010 Plugin with EHR system benefits are built with PHEV in mind and we have yet to see real-world MPGs. I am guessing it will be much better. I hope so because if the result is good, they should sell it to the public.
  7. Jared
    Jared Member
    209
    Long Island
    I drive about 100 miles a day. Plug in would not benefit me enough to justify the bigger battery.
  8. drees
    drees Senior Member
    1,782
    247
    Actually, those are the results from their designated test drivers driving on a designated course instructed to drive each vehicle as similarly as possible.
    If you look at how the actual "fleet drivers" do, their fuel economy is substantially worse, though not as bad as the ones in the study in the OP.
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    google's FEH #'s are not very impressive. i know a guy in town getting almost 40 mpg.
    however, the google data, staged as it was i would definitely consider valid. google is become a company imm (whether deserved or not is another topic) that thinks more on my level than any other company its size i know of. i think they pulled all stops to insure a good database which does include relative data points (the ICE vehicles) to compare with...i just about busted out laughing when "unexpected maintenance issues" came up....(shall we blame the ford for this one??)
    i still studying the final data since i have to wonder how they put together the final chart especially when both the FEH and Pri PLEV were getting around 133 watts per mile which is not a realistic figure. i guess they are using charge depleted over miles driven which include miles where the battery pack was empty which would lower that figure.
    also wondering if the figure is using charge depleted with the data logger or if its using power input from the wall ala Killawatt or something?
  10. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Keep in mind the above is from their experiment. They posted the methdology at RechargeIT.org.
    They have a small fleet for which they have data at Google.org. They list economy for non-PHEV Priuses at 40.1 mpg and 57.6 mpg for their larger set of plug-ins. Glancing thru the June 09 for some of the cars, some have undergone very short drives and days of non-use (no driving) in between, so the coolant in the thermos has probably cooled down signifanctly.
  11. hill
    8,805
    Curious about the conclusion. I'm thinking that even if I DID have to drive 100 miles a day (versus only the 38 miles that I actually drive per day), a plugin WOULD benefit enough to justify "getting one". Not sure if, "... justify the bigger battery." means the same thing as getting one. I'm thinking a PHEV's benefits would justify the cost ... justify the (space taken by?) bigger battery.
    Some PHEV drivers won't/can't drive efficiently. That doesn't mean most others can't drive efficiently. Here's a chart from one of the many conversion companies.
    They'll also use 1 cent/mile of electricity.
    There's a whole batch of folks throwing out, "break even point" even relating to regular hybrids. What they're saying in so many words is that they want to "make money" on their hybrid's fueling ... and not only do they want to make money on their fueling ... they want it (some esoteric 'break even' point) in "under 6 years" ... or under 4 or 2. In otherwords, unless there is still another drop of fuel to use, "why change" untill then? The PHEV just takes the, "it won't benefit me" to another level. Petro dollars going to terrorist-supporting countries doesn't benefit people either. Decisions decisions.
