(Request) Brake Light Pictures
Discussion in 'Prime Main Forum (2017-2022)' started by SaraBBrown94, Feb 16, 2018.
  1. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Cheer up! You can see photos of the dark side of the moon taken by lunar spacecraft, or listen to the album by Pink Floyd! For your brake lights, I'll send over my neighbor!
    AChoiredTaste.com
    pilotgrrl, benagi, bisco and 2 others like this.
  2. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    I note that a couple of photos from Toyota's marketing material have already been posted.
    My method of checking both front and rear lights is to pull up perpendicular to the show window of a closed shop in a shopping center. It's easy to see the reflection of your light pattern of the front of your car and, less easy but possible, to see the rear light pattern in your mirrors when you back in. Or use your back-up TV camera, and the reflection then will also show the back-up lights being on.
    HPrimeAdvanced likes this.
    52,880
    or put your phone on a small table behind the car.
    Since2002 and HPrimeAdvanced like this.
  4. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    I ran over my small table; my neighbor yelled when I ran over his foot, so I knew I had to stop!! Har, har
    AChoiredTaste.com
  5. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Good idea then you can also test out the ICS system at the same time to see if it reduces the impact speed when backing into the table. If it knocks your phone off the table and breaks it, then you know you need to schedule an appointment at the dealer to check out the ICS. Unfortunately you won't be able to call to make the appointment.
  6. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Yeah butta I heah that about 20 or 30 yeahs ago, Martha, there was dis ting called a "Landline" or sumpin' like dat, where you could call somebody!!?? That's what I remember. I do not know, maybe I'm just getting old!!??
    AChoiredTaste.com
    priuscatprimeguy and Since2002 like this.
  7. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    I remember this thing called a pigeon. You tied a note to its leg and sent it on its way. I guess luck got it to the right address each time.
  8. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    I wonder what kind of security protocols they were using then, to prevent hacking!!
    AChoiredTaste.com
    priuscatprimeguy likes this.
  9. Prodigyplace
    12,720
    11,852
    Central Virginia
  10. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
  11. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The cars are dirty because the Pigeons flew over them.
  12. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    I found a magnetic surface to stick my phone too so I could take pictures. So in order braking, backing up, backing up and braking, braking with the car off, driving normally.
    1519449742387.jpg 1519449749147.jpg 1519449753238.jpg 1519449760296.jpg 1519449768090.jpg
  13. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    In Ma my car failed inspection with a license plate holder like that.
    It covers the top part of the plate.
    But at least the inspector took the cover off the plate,passed the car, and handed me the covers after the inspection.
    Instead of failing me, and making me come back.
    Very nice of you to fulfill the request !
    jp
  14. SaraBBrown94
    234
    263
    Pittsburgh PA
    Not sure why they would care too much. The only thing the plate is covering is a couple millimeters of blue. The state name and majority of the state colors are visible. Around here, you're lucky if you can even read people's plates. They're either covered in mud and dirt or the letters are entirely rubbed/faded to white. Lol we no longer use registration stickers so those aren't there either
  15. bisco
    52,880
    the dealers put them on here, and the inspection stations remove them.:rolleyes:
  16. Russ Bohn
    Russ Bohn Junior Member
    31
    Overland Park, Kansas
  17. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Never will, either, since there is no dark side of the moon.
    SaraBBrown94 likes this.
  18. bisco
    52,880
    sure there is, you don't remember pink floyd?:cool:
  19. Lee Jay
    5,850
    4,036
    I try not to.
    Prodigyplace likes this.
  20. bisco
    52,880
    i'm not surprised.
