Request for Advice: 3.5yrs 12V Battery Replacement Time?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tjw, Oct 12, 2012.
  1. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    I got caught up in the MPG issue and forgot about the OP. I would say the OPs battery has a problem being left to sit for long periods of time. Seems like if the car is going to be driven daily he can keep it and if he plans to let it sit again, he might want to replace it.
  2. 2006_HK
    2006_HK First Hybrid
    74
    Santa Clara, CA
    Please let it go on until it works. Given the voltage, you would probably have the record for the longest running original battery. 10 years would be awesome. :)
  3. Avi's Advanced Automotive
    776
    363
    Looks like 10 years isn't going to happen. I just tested it:
    52,812
    ya, my 04 lasted until last spring. not too shabby. fortunately, it didn't die and mpg's never went down. it just started doing funny things like sks touch handle wouldn't work and you had to hit the fob. then after a few weeks, you had to put the fob in the slot. then one day, i needed a jump. but i knew that was coming and was prepared. i think the older batteries were built better.
  5. John H
    John H Senior Member
    2,208
    558
    so just for grins, and while the Prius is home for the weekend, I went out this morning and hooked up the charger at the jump start terminal under the hood. It was 12v+ on a voltmeter before connecting and the charger immediatly pumped in 6amps @ 15V. Within 5 minutes it had dropped below 2amps. That is what I would expect for a healthy battery.
  6. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Be careful when using that battery charger on the Prius battery as it should not be charged at a rate higher than 4 amps (directions on the battery and in the handbook). As this can cause it to gas to much and release pressure through the safety vents, and overheat. This dries the battery out causing it to fail. I am sure for the length of time you had it on charge no damage will have been done, but if left unattended for a few hours could easily do so.
  7. tjw
    tjw Junior Member
    VA
    Thanks for all the feedback.
    The battery was jumped on Monday night and the car was used Tuesday through Friday for the normal 40-mile- round-trip commute. Everything seems to be fine and this was the first time the 2009 wouldn't start.
    I've never charged the battery and I think 10 days of sitting in the garage was too much. Plus, Monday morning when it failed to start was colder than usual.
    My plan is to buy a charger and charge the 12V battery once a month.
    Any recommendations for a 12V battery charger that works well for both Gen II and Gen III models?
  8. 2006_HK
    74
    Santa Clara, CA
    I use battery tender brand and it has been working fine for about a year (charging once a week roughly). I have also heard good things about a product called battery minder. It seems that can de-sulfate your battery to improve its life. Have never used it though.
    I like the slow charging one but there is also a 1.25A version. One drawback is that I have to open the hood to connect it every time. It has ring terminals but unfortunately, they are not long enough to come out in front of the hood. That would have made connecting the charger really easy.
    Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger : Amazon.com : Automotive
    BatteryMINDer Model 12117: 12 Volt 1.33 Amp (12V 1.33A) Charger/Maintainer/Desulfator : Amazon.com : Automotive
  9. Britprius
    5,194
    1,922
    Sorry I cannot recommend a charger as I am in the UK but I would look for a charger that is suitable for AGM batteries and has an output of around 2 amps or is switchable to this. An automatic 3 stage charger would be best but a simple 2amp charger would be fine just left on over night.
  10. John H
    2,208
    558
    I replaced the OEM battery with an Optima YellowTop about a month ago. OptimaJim has indicated 10A is fine for this battery, but the warning is appreciated.
  11. tjw
    tjw Junior Member
    VA
    I thought I would share my final results from my dead 12V battery.
    I bought the 021-0123 Battery Tender Jr (12V 750mA).
    Full Charge for GenII 2009 3.5 yr old = 5 hrs
    Full Charge for GenIII 2010 3.0 yr old = 50 min
    Gen II 2009 Test After Jump Start and Battery Fully Charged:
    12.4V no load
    11.9V headlights
