Required minimum coolant temperature
Discussion in 'Gen 3 Prius Main Forum' started by Yaesu, Dec 8, 2021.
  1. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    During start up, what coolant temperature is required before the engine will turn off?
  2. Mendel Leisk
    42,352
    Hard to answer. It's not just engine temp that governs engine shut-off during warm-up. Some other factors:
    1. Temp set on the Heat/Vent system. With partially warmed engine, if you roll to a stop and engine continues to run, try ticking the temp down a degree or three; often engine will shut off. Or turn H/V right off might be needed to do the trick.
    2. Mode set on the Heat/Vent system. Heat/Defog mode in particular will tend to keep the engine running.
    3. Outside air temp. Well this one I suspect, but it seems to be: if it's bitter cold, it seems to take that into consideration, delays engine shut-down till higher coolant temp is reached.
    4. Goes without saying, but: Hybrid Battery state of charge down to two bars.
    #2 Mendel Leisk, Dec 8, 2021
  3. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    It's much more complicated than I thought. However, somewhere in the back of my mind I remember reading something about the minimum coolant temperature before the engine turn off. Perhaps I should connect the Scangauge to the Prius instead of the motor home.
  4. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    Some info I copied back when I had my 2010 IV...
  5. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    That is a lot of information. Thanks. I think 140F was something I remember reading about.
  6. hoffeck
    hoffeck Member
    Germany
    If the heating is deactivated, the engine switches off at 40°C / 104°F.
    SteveSco and StarCaller like this.
  7. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    Not yet mentioned is the need to heat up the catalytic converter so engine exhaust burns cleaner... And partially mentioned is how much charge the hybrid battery has, as engine will idle longer before shut off if charge is low.
    jzchen likes this.
  8. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    I asked the question because today (temp. 30s to low 40s) I noticed that the drive battery remained at a higher charge than usual. I figured it was because the engine had to run more than usual to maintain cabin heat.
    104F sounds reasonable, based on the short minimal length of time the engine runs at warmup on a hot summer day.
  9. Mendel Leisk
    42,352
    I can reliably get EV mode at start-up, IF I plug in the block heater for at least an hour. good for maneuvering the car out of the garage to the driveway or street, stuff like that. It kicks me out if I exceed ~15 km/hr.
  10. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    That is a nice option with the Prius. Occasionally I move the vehicle and try to do it in the EV mode before the engine starts.
  11. fuzzy1
    10,710
    That is what I see, at least while in ECO mode.
    My engine coolant temperature needs to be above 68F / 20C to get EV mode.
    Curiously, I've never ever seen the OBDII-port / ScanGauge display 68F. Always 67 or 69F instead, over very many observations. And once managed to watch it transition from 69 to 67, cancelling EV and starting the ICE.
  12. PriusCamper
    13,467
    5,434
    Wow, I wanna do that... Does it work on Gen2 as well as Gen3?
    Do you have a link on here to describe the block heater you used, as well as install advice? This is exciting! What's temp the block gets coolant up to?
  13. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,603
    Taylors, SC
    Monitoring coolant temperature continuously with my ScanGage 2, the ICE usually cuts off in the 120-130 degrees F, range.
  14. Mendel Leisk
    42,352
    I haven't been bothering with my ScanGauge for a while. For one reason, because it was starting to trigger "Check Hybrid System" warnings.
    Anyway, I found an hour with the stock Toyota block heater plugged in was enough, on the coast just up the road from you. Maybe a little more if it's near freezing. You've got about 15 seconds after start up, to try for EV, and see if you get it. If not, shut down quickly and let the block heater go another 1/2 hour. But an hour always seems to do it for me.
    As @fuzzy1 notes, it "might" be on the cusp, will give you EV, but then coolant temp drop a degree or two and it decides to kick in the engine. So far it's worked well for me though.
    It's a little odd, but it seems like US dealerships don't usually have the block heater. Not sure why, because it can a LOT colder in north/central States than out here on the coast. Anyway, this is the part number, when I replaced ours, in Oct 2019:
    PU140-00905
    It was $90 CDN, they had to order it in; took a few days.
    I installed it myself this time. On third gen it was a royal pain. A factory install before the engine is dropped in would straightforward, but the bear is all the cables/conduits/brackets in the effing way if you do it after the fact. It's a heater bar that goes into a socket on the drivers side rear corner, round back of the engine. There's a thermal transfer lube you apply to it.
    I would dry fit it first, and that means unbolting brackets, and pulling/tying stuff out of the way as much as possible. I also raised the car and took off the undershield (2010), and did the final insert reaching up from below. You can't see what you're doing. Put it in dry, then just back it out, get the grease up there, baste it up, and back in. There's a tang that snaps into a pocket to lock it in place. And for sure have the power cord pushed into the heater element first.
    Here's the Toyota Instruction for third gen, but it doesn't really address the difficulty of access (part no superceded). I didn't take the wipers/cowl off, but it mighta helped:
    #14 Mendel Leisk, Dec 9, 2021
    SteveSco and PriusCamper like this.
  15. AzusaPrius
    AzusaPrius Senior Member
    2,257
    950
