Reroute egr path?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by whitrzac, Mar 27, 2024.
  1. whitrzac
    whitrzac Junior Member
    46
    madison
    My understanding is that the egr plugs causing an imbalance afr between the cylinders, causing detonation and hotter temps, eating the hg over time.
    Has anyone rerouted the egr into the pcv opening on the manifold or drilled/tapped a new single port that would feed all cylinders equally?
  2. Mendel Leisk
    42,387
    Where the engineers positioned the exhaust gas introduction into the intake air, is at the very end of the intake manifold path, at most a couple of inches from the intake valves, perhaps for good reason?
  3. whitrzac
    46
    madison
    Or not because it's considered one of the least reliable engines toyota has built
    Paladain55 likes this.
  4. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    Clean it or delete it. Yup they did it incorrectly. They fixed it in later revisions after gen 3.
