Rerouting the CarPlay USB to the center console
Discussion in 'Gen 4 Prius Accessories and Modifications' started by 2022PriusLimited, May 24, 2022.
  1. 2022PriusLimited
    2022PriusLimited Junior Member
    2022 Prius
    I'm looking to re-route the USB in my 2022 Prius from the cupholder area, to the inside of the center console (arm rest). Whether my phone is plugged in, or I have a Carplay wireless dongle plugged in, either will take up a cupholder, and the cables become a mess. My old Prius had the USB located inside the center console - not sure why it was moved outside.
    Does anyone have any guidance or ideas about re-routing the USB from where it is by the cupholders to the inside of the center console?
  2. MalachyNG
    MalachyNG Active Member
    304
    227
    Northern NY
    2022 Prius Prime
    I have a wireless AI box that I plugged in with a flat USB cable and then put it in my armrest storage. The armrest can close and it doesn't pinch the cable.
  3. 2022PriusLimited
    2022 Prius
    Which box did you go with?
    Ideally I'd not have the cable there, but I do think this is a solution.
  4. tomguild
    tomguild smugmobile owner
    28
    Raleigh NC
    2021 Prius
    I had a similar issue; I bought a short USB extender so that the big CarPlay dongle can live in the armrest. It's sometimes a little hard to close the console lid but it usually works fine, and it un-cluttered the cupholders. Also, sometimes I have to "reboot" the CarPlay dongle when it doesn't connect to the phone. At that point having the car's USB port on the outside makes it easier.
  5. 2022PriusLimited
    2022 Prius
    Which wireless carplay dongle did you get? Would you recommend it?
  6. tomguild
    28
    Raleigh NC
    2021 Prius
    Carplay2air - Cplay2air.com. It's pretty reliable. The extender was a generic cable from Best Buy.
    RojaRosie and MIkeDr like this.
  7. PixelRogue
    489
    86
    US
    Imagine this is handy. Have you run into battery drain given that the device is no longer plugged into the console?
