1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Reset oil maintenance on Japanese model with no MPH/KM button
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by garyasta, Oct 20, 2020.
  1. garyasta
    garyasta Junior Member
    New Zealand
    I have an imported Japanese model with most signs etc. in Japanese. There is no MPH/KM button and being a Gen3 model, doesn't have the ODO button of the Gen2. There is a button (to do with screen brightness, I think), situated above the clock buttons. Should this be used instead of the MPH/KM button when resetting the oil maintenance setting?
  2. NewHybridOwner
    NewHybridOwner Active Member
    607
    278
    W. Michigan
    Try this:
    How to Reset Toyota Prius Maintenance Light - CAR FROM JAPAN
  3. garyasta
    New Zealand
  4. NewHybridOwner
    607
    278
    W. Michigan
    Sorry about that! I didn't remember the details of your message when I went looking.
  5. aziatiq
    aziatiq New Member
    United Kingdom
    Did you ever figure out how to do it? I just changed my oil in my JDM Prius and I wanted to reset the oil maintenance setting.
    I read somewhere that instead of using the MPH/KPM button, to use the TRIP button instead on the steering wheel. I did that and nothing happened.
    Also, I was reading somewhere else on the forum and saw that the Canadian Priuses don't have the oil maintenance feature. So now I'm curious to see if Japanese models are similiar.
  6. garyasta
    New Zealand
  7. garyasta
    New Zealand
    Sorry, I was not able to find a solution that didn't have the use of the MPH/KMPH button.
    aziatiq likes this.
Loading...
