Results from almost total discharge of a Gen 2 module
Discussion in 'Gen 2 Prius Technical Discussion' started by TMR-JWAP, Mar 18, 2017.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,362
    6,033
    Columbia, SC
    Did a little experimenting with a Gen 2 module that had maxed out at ~3000mah capacity even after 5 discharge/charge cycles. It was interesting to see that the chart shows how one bad cell affects the module.
    Everything was looking great just before the 18 minute mark. Current draw was 6.5 amps and terminal voltage was 7.3, hadn't even reached the 7.2 volt plateau when BANG, the first cell failed. It then went 32 more minutes at 6.5 amps before the next one failed. Then they fell like dominos.
    Raytheeagle and SFO like this.
  2. Hybrid Battery Exchange
    67
    84
    Portland, OR
    At 7.86 resting voltage you didn't even start out at full charge, pretty healthy module besides the one cell crapping out after 1.95ah. In my experience there is absolutely no recovery (unless you start drilling holes and adding liquids).
  3. Cody26
    Cody26 Junior Member
    86
    Raleigh, North Carolina
    How do you know that cell was lost by the jump you observe in a voltmeter?
  4. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    I think that was an experiment performed by Bill, some years ago? He did recover some lost capacity, but problem was how to seal the drilled holes.
    Dxta
  5. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    See reply #4
  6. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Dxta
