Reverse alarm inside dash?
Discussion in 'Gen 3 Prius Main Forum' started by LDB, Sep 4, 2015.
  1. MoDianePrius2013
    MoDianePrius2013 Junior Member
    Plano
    Personally the constant beeping is annoying but a single beep would be nice. Dealership programming is free as I understand?
  2. CR94
    CR94 Senior Member
    2,813
    1,235
    Northwestern S.C.
    That's a somewhat plausible scenario, but one could just as easily make the same error with a non-hybrid, on which reverse beepers are not required. The lack-of-a-clunk excuse wouldn't apply in that scenario. I wouldn't mind it so much if it weren't so alarmingly loud.
    LDB likes this.
  3. PerryD
    PerryD Junior Member
    27
    34
    Near Boston
    2022 Prius Prime
    I wish there was a mod to reverse the shifter functionality. It isn't intuitive to move the shifter forward to go backward and backward to go forward...
    LDB likes this.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Sadly NHTSA regs say that the shift pattern has to be PRND clockwise around the steering wheel, so it is. (B or L can be anywhere in the pattern)
  5. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    I believe it depends on the dealer, your negotiating skills, and when its done.
    • It's easy to get it done as a condition for buying the car.
    • If they are hooking up to the car's computer anyway for another purpose then its easy and quick for them to do it.
    • If they are doing it as a special task, it's a little more work (find the instrument or wait till its available and hook it up). It's still not much work but they probably have a minimum (not necessarily minimal) charge they want to apply.
    If they want an unreasonable charge, my approach would be to politely express my concern that the continuous beep is very distracting to me and I am concerned about the safety hazard, particularly given the challenging sight lines of the car. I'd then express my astonishment that the problem won't be fixed for free as Toyota has not made it owner programmable.
  6. energyandair
    905
    339
    Victoria BC Canada
    IIRC, an internal beep for reverse was Toyota's choice, not a regulatory requirement. I like the single beep but hate the continuous beep. Some others feel differently so its good to have the choice
  7. Mendel Leisk
    42,238
    If you're adamant to completely disable it, there's surely a connector you could disconnect. Still, this is there for SAFETY. For you, or future owners.
  8. CR94
    CR94 Senior Member
    2,813
    1,235
    Northwestern S.C.
    Until proven otherwise, I'd be concerned that disabling it by crude methods such as cutting or unplugging a wire might also disable other warning beeps that are actually valuble. The loud continuous inside reverse beeper, in my opinion, is not a safety feature but a HAZARD, because it tends to induce undue panic, and because it would make it difficult to hear any warning that might come from outside the car.
  9. Mendel Leisk
    42,238
    I'd describe as a patch, for the shortcomings of the novel shifter design.
  10. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    That's one of the MANY reasons why I like my Prius, because it is there!
