reverse camera and line
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by J2014, May 31, 2014.
  1. J2014
    J2014 Junior Member
    37
    2014 Prius Plug-in
    Anyone know if there is a way to turn on the line for the backup camera? I thought I saw a green line before but now I don't?
    Is there a way to turn off the reverse beeping?
    Thanks
  2. Markee
    Markee Member
    325
    50
    South Florida Broward County
    As far as turning off the backup camera beep there is a way read the below link I don't know if there is any way to turn reverse guide lines on maybe someone else maybe can answer that ?
    Carista OBD-II application rocks | PriusChat
  3. Astolat
    Astolat Member
    229
    73
    Guildford UK
    There was a post recently sketching out the scenario where you backed up a little because you had gone over the line at a stop signal, then got distracted while your foot was on the brake, then the light turned green... It convinced me not to get the reversing beep turned off, even though I always reverse when I park, at home as well as in car parks.
  4. El Dobro
    El Dobro A Member
    7,003
    3,226
    It doesn't have the assist lines.
  5. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    Unlike the 2011 Five I had with the Advanced Technology package.
    The backup camera in my '14 Advanced with Tech package has no lines, and frankly provides no guidance for distance. It's almost worthless.
  6. El Dobro
    El Dobro A Member
    7,003
    3,226
    It's funny, other manufacturers have dropped the lines, too.
    rxlawdude likes this.
  7. GregP507
    GregP507 Senior Member
    3,002
    480
    I don't need the lines. After a bit of practice, I can tell approximately how far away is an object on the screen. What I do need is a front bumper cam, and if possible, a right-side cam. I have two such cameras on the way from China as we speak, and I'll see if there's a way to tie them both in to the display screen.
