Reverse camera installation
Discussion in 'The File Library' started by Terry Dactil, Nov 23, 2005.
  1. Jayw13702
    Jayw13702 Active Member
    142
    170
    Plymouth UK
    Does anyone know where I can get one of these converters?
    Mine is a 2004 and I would love to fit a rear camera
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    The camera harness on all American 2007 Prius including base resides in the hatch right past the rubber bellows wire protector about 6 inches in the hatch. Just take black plastic cover off inside hatch the one by the hinges. Its a 4 pin connector.
    You have B+ and ground and camera video input and camera input shield.
    On base models with no camera its still there as its part of a very large integrated harness.
    If no camera its a base model. Buy a prius camera at junkyard and just plug it into that harness.
    Neural Net likes this.
  3. dmf415
    dmf415 New Member
    I have a 2008 and am not seeing any other 4 pin connectors or wires running into the hatch. Can u take pics?
  4. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Do you have a base no camera or sks?
  5. dmf415
    dmf415 New Member
    I have a base model prius with no nav and no backup camera
  6. dmf415
    dmf415 New Member
    Also no smart key too
  7. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Package level info:
    2G Prius (2004-2009) Standard and Optional Equipment (Some Countries) | PriusChat
    In the electrical service manual it appears that camera harness is part of a very large main harness that goes from the dash to the hatch area to support all the lights etc. If you do not see it then its a separate harness.
    It goes through the rubber bellows into the hatch and will be somewhere inside the hatch. Have to pull off all the flimsy black plastic panels.
    Its a four conductor cable terminating into a plug. If its not in the hatch then it appears it is a separate harness and not installed in a base no camera trimmed car.
    They must use a different harness for that car. Bummer.
  8. dmf415
    dmf415 New Member
    thanks, looks like my prius is a package #1 prius which is slightly better then the base. i have cruise control.
  9. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    I have a prius base, no nav and no cruise, Is there a adapter or plug to plug a generic camera I to the mfd? Or does this only work on the nav model?
  10. dmf415
    dmf415 New Member
    I found the harness finally. It is part of a larger harness. The wires are red, white,black and gray... How do I hook this up to am oem/ factory camera?
    The cameras I've seen on ebay or only 2 wire.
    redcoral likes this.
  11. redcoral
    redcoral Junior Member
    Georgina, Ontario
    I have a 2007 with smart key, but no nav or backup camera and I wasn't able to find the wiring harness. I think our cars may be pretty similar. How difficult was it to get at the harness? Did you/could you take photos?
  12. DangNabbit
    DangNabbit Junior Member
    55
    Where the wild things are
    I
    I recently bought the OEM backup camera.
    Does anyone have pictures of the Backup camera wiring harness location? I took the plastic covers off the rear hatch. I managed to lose one of the white clips inside the hatch... hopefully I can find it.
    I have a 2008 Prius level 1 with cruise control.
  13. 13b_kl
    13b_kl Junior Member
    Romania
    Do you have the STL/CAD from the "display shader" and be so kind to share it? Thanks!
