Reverse gear beeper. How to disable it?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Bilel734, Jun 12, 2017.
  1. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    The beep may not be able to be turned off completely, because it's mandatory in Japan. All Prii are built on the same line in Tsutsumi, Japan.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    No - it'll go from eternal beeping to just one beep.
  3. Prodigyplace
    12,712
    11,848
    Central Virginia
    Perhaps it's different in Australia, but on the default setting mine quit beeping when it was taken out of Reverse. ;)
    alanclarkeau and krmcg like this.
  4. Mendel Leisk
    42,345
    Considering it's just those few seconds when I'm in reverse, I can't get too lathered up about the beeping in reverse. What does bug me though:
    I don't think it's effective, at it's purpose, which is to alert you that you're in reverse, an alert made necessary by the cutesy return-to-centre electronic shifter. For me it's "the boy who cried wolf": the steady beep is ineffectual, does not directly register in my brain as "you're in reverse", and more than once I've just caught myself, started to give gas and realized I was not going in the direction I expected to go...
  5. alanclarkeau
    7,045
    7,593
    @Prodigyplace - hmmm - for a better word - I thought "incessant" might be better - but GOOGLE says is endless too. Maybe I need to invent a word.
    I guess it depends on how long your driveway is - I've got a few long ones which I reverse in or out of - I'm glad it doesn't go the whole time. Life has too many beeps.
  6. chinarut
    chinarut Junior Member
    2019 Prius
    hmm - I would definitely be interested in this - I assume the one beep is that "initial beep" and that's it? for those who have done it, is 1 beep enough of a reminder you are in reverse? I do get its safety benefit and what I really want is to lower the volume (like the OP) and to increase the delay between beeps!
  7. Mendel Leisk
    42,345
    Even the continuous beeping has not always been effective for me.
    chinarut likes this.
  8. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    The dealer changed mine to single beep before I took delivery as part of their PDI.
    I have never not known what gear I am in as an always double check the display before moving off.
