Reverse light fuse
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by djmj, Nov 24, 2013.
  1. djmj
    djmj New Member
    I'm trying to locate reverse light fuse. Because I replaced the bulb and it's still not working.
    Toyota Prius 2010 UK
    Any help?
    Thank you
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    It may be #30 "Tail" in the inside fuse box.
    Should be 10 amp...
  3. djmj
    djmj New Member
    thank you but no this fuse is working fine
  4. RRxing
    RRxing Senior Member
    2,516
    1,789
    NEPA
    Assuming the fuse layout is the same (UK/US), try #19 (40A) in the engine compartment fuse box. See Attached. Good luck.
  5. djmj
    djmj New Member
    Thank you for your replay yes the layout is this same but no it's not this fuse because horn and everything else is working fine
  6. Omar Barlas
    Omar Barlas New Member
    North Richland Hills, Texas
    Did you ever resolved this issue of Back-up Lights not coming ON when i put in reverse, Fuse #19 should be fine as the horn and other lights are working fine, and both bulbs are good too, basically we are not getting any voltage on bulb holders when i put in reverse.
    This problem started after i hooked backup camera power cable one of the back-up lights, now even if i detach it , the light still does not comes on.
  7. Rarmstrong595
    Rarmstrong595 New Member
    Volcano, HI
    Did you ever get the back up light to work? I have a 2007 Prius that presents the issue you have (or had???)?
