Reverse light short cut wire
Discussion in 'Prime Audio, Electronics, and Infotainment' started by MSF1344, Dec 30, 2019.
  1. MSF1344
    MSF1344 Junior Member
    61
    UK
    Active
    Hi , I need a shortest route from reverse light to behind my head unit to connect to the red wire of my camera . Is there any ?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I'm guessing this camera is in the back of the car? If so, wouldn't the wires in the hatch to one of the backup lights be closest?
  3. MSF1344
    61
    UK
    Active
    The camera in installed already and the wiring is behind the dashboard . the problem is I bought a new head unit which the harness connector is totally different with the genuine camera harness . so for connecting I need a wire from the reverse light to the head unit and I dont want to disassemble all the boot covering and etc .
  4. jerrymildred
    11,517
    14,167
    Tampa, FL
    I would think that the wire to the brake lights would come out of an ecu, but I've never looked into that. Might be best to rent the shop manual from Toyota. I think it's about $15 for two days.
