Reverse Polarity Jump Start - Gen3 Prius wont Start
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Chukhtai, Oct 11, 2022.
  1. Chukhtai
    Chukhtai New Member
    London
    2013 Prius+ MPV
    Help please
    I droped off my car for body repair then guy who works there tried to jump start because car stationed there for few weeks ,
    now can not get in ready mode ,
    1) tail lights,fog lights,wiper,radio,windows NOT WORKING
    2) Head lights,turn lights, OK
    3) All blade fuse OK
    4) fuse voltage checked under hood fuse box recorded between 10 to 10.50
    I don`t know if 125a DC/DC fuse blown or any problem with relay
    Please somone help me
    really appreciate your help
    #1 Chukhtai, Oct 11, 2022
  2. Mendel Leisk
    42,310
    Chukhtai likes this.
  3. ChapmanF
    18,996
    The 125 amp fuse is very difficult to access, but there are easy test points you can reach with a meter probe from the top. If voltage is there with the car off (or if there is continuity from there to the jump point) the fuse is ok. Stick a meter probe down into the square opening with the green arrow here, or (even easier), touch it to the green-indicated test points on any of those three fuses directly above it. (Isn't it handy these blade fuses have test points on top?)
  4. Chukhtai
    Chukhtai New Member
    London
    2013 Prius+ MPV
    Thanks a lot really appreciate,
    Will do it ,square arrow you point is it lead to 125 dc fuse ?
    Why I am getting voltage 10 to 10.50 if 125 dc fuse blown?
    I will test and update ,
    Thanks
  5. Chukhtai
    Chukhtai New Member
    London
    2013 Prius+ MPV
    Hi ,
    Very difficult to reach 125 dc fuse ,
    It is ok if I just try and change White big relay to see it works ,
    I will use this relay from other Prius
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,059
    6,928
    Texas Hill Country
    You can just look at the 125a if you know where to look. Replacing it is another issue requiring removing the fuse box from the fender. Some have bypassed it but that is not recommended and requires almost as much skill. Typically a few smaller fuses go with the 125a.
    Fuse box Bottom View
    Fuse box bottom view typ.JPG Two tabs shown on this bottom view release from the fender.
    Other resources:
  7. Chukhtai
    Chukhtai New Member
    London
    2013 Prius+ MPV
    Thanks for information,
    Should I also check big white relay on the fuse box or it is just 125a dc,
    Is it do able can I pull up the half fus box ?
    Thanks I will appreciate your response.
    Is this 125a dc a problem.
    Thanks
  8. rjparker
    11,059
    6,928
    Texas Hill Country
    The relays are normally ok in a reverse polarity jump scenario.
    These are blown fuses. One with stripped screws. A8ABED84-6085-4C58-A311-BFB08D12BDA4.jpeg
    #8 rjparker, Oct 11, 2022
  9. ChapmanF
    18,996
    That square place, and all three fuse test points I also marked, are places you can test for voltage as a way to find out whether that fuse is blown or not.
    If the battery is connected, and you see battery voltage at any of those points, the fuse is good. If you see no voltage, the fuse is blown.
    Equivalently, if the battery is not connected, you can use an ohmmeter between any of those points and the provided jump terminal. If continuity is shown, the fuse is good. If no continuity, the fuse is blown. (Only if the battery is disconnected should an ohmmeter be used there.)
    As rjparker points out, from certain angles you can also get a look at the fuse. Usually a blown fuse will look blown. My habit is still to use a meter, though, because I have been fooled by looking at fuses before.
  10. Chukhtai
    Chukhtai New Member
    London
    2013 Prius+ MPV
    thanks chapmanf and rjparker ,
    I will check and update ,
    is it good idea if i buy fuse [​IMG]box cost me 70 pound and then take out 125a dc fuse then replace it ?
    I will check with toyota today to buy this fuse.
    #10 Chukhtai, Oct 12, 2022
  11. rjparker
    11,059
    6,928
    Texas Hill Country
    Were you able to verify the 125a fuse in your fuse box was bad?
    I would imagine the fuse in your salvage fuse box is fine. It is unlikely your existing fuse box is bad. Typically, once you determine your fuse is blown you replace the fuse. Yes, removing the fuse box from the fender is necessary but then the box comes apart. We just did not get to that point yet.
    If you have already bought the salvage yard fuse box, you could take it back and just buy the fuse for much less.
    If you do replace the fuse box, carefully verify that all fuses and relays in the new one match the existing. It looks like one of the mounting pegs of your salvage box is broken off but that won't keep it from functioning.
    Here are some pics from both of us that are found elsewhere on this site. Unfortunately the moderators don't do much to organize or clean up the forum and members can't even update our own posts after 24 hours. These are not guaranteed accurate but you get the idea.
    #11 rjparker, Oct 12, 2022
  12. Chukhtai
    Chukhtai New Member
    London
    2013 Prius+ MPV
    thanks for information
    I have followed the procedure to test the fuse ,
    Voltage test failed
    continuity test failed
    so it is a little monster sitting inside very difficult to access i have tried to unlock the clip but not possible or maybe i am doing it in the wrong way ,
    i will update
  13. Mendel Leisk
    42,310
    @chuktai you should let body shop know what they’ve dropped to you into.
    Also, could Toyota be doing something better, say ensuring only one fuse need blow, and making it readily accessible??
    #13 Mendel Leisk, Oct 12, 2022
  14. rjparker
    11,059
    6,928
    Texas Hill Country
    First, Toyota has done something amazing with their module protection in that a high energy reverse polarity jump does not blow any of them. A fuse will not be fast enough to save subpar modules. Plus many are on the unprotected side of this fuse.
    Second, the smart thing for anyone to own in 2022 is a lithium jump pack that does not allow reverse polarity jumps. Yes, a more accessible fusible link would be handy as would an easier to remove box.
    A knowledgeable mechanic can bypass the 125a with an external fuse but the method requires a clear understanding of the circuit and proper corrosion protection. I don't recommend it because the downside of a bypass mistake could result in widespread burning of the wire harness. However if this happened to me I would be on my way the same day using a generic fuse and fuseholder.
    #14 rjparker, Oct 12, 2022
    Chukhtai and Mendel Leisk like this.
  15. Chukhtai
    Chukhtai New Member
    London
    2013 Prius+ MPV
    unable to remove the fuse box ,
    i will get the fuse tomorrow from Toyota cost 28 pound , i have strugle two hours but the fuse box is stuck with fender
    any idea how to remove it thanks
  16. rjparker
    11,059
    6,928
    Texas Hill Country
    I have never done it, but most people simply pry it off. It would appear that access from inside the fender well might be possible.
  17. Chukhtai
    Chukhtai New Member
    London
    2013 Prius+ MPV
    Thanks for help
    I have changed the fuse every thing fine but dashboard show engine sign.
    My car left tyre is open removed do it tomorrow,
    Why engine sign there rest is fine .
    Thanks
  18. Mendel Leisk
    42,310
    Everything seems fine now, apart from the check engine light? The car starts up and drives normally?
    I think it's usual for a check engine light to stay on, even if everything is fine, for about 5 more start ups. If everything seems fine, you could just try driving for a few days, see if the light goes away.
  19. rjparker
    11,059
    6,928
    Texas Hill Country
    Hopefully you have checked for codes, wrote them down and then cleared them. It is possible and likely that other normal fuses are bad but the engine still runs.
    What did you do to change the 125a? We need to get a definitive procedure.
  20. Chukhtai
    Chukhtai New Member
    London
    2013 Prius+ MPV
    Thanks to everyone for help,
    It took me 8 hours to fix it , I will make a video and will share ,
    Tomorrow I will install inner cover of the fender side ,
    Very tough job .car looks good except the engine sign
    Thanks
