Reverse Polarity Jumpstart, Strange Symptoms
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Boefinator, May 16, 2024.
  1. Boefinator
    Boefinator New Member
    So....I was in a rush after returning from a two week vacation to find my 2017 Prime Advanced dead. Jumped started using Jeep, but crossed the wires from the donor car. Long story short, the main fuse was fried, same with some fusible links and the dome fuse. Replaced all that and luckily car came back to life.
    But there are persistent issues I can't figure out. When the car is off, none of the 12v systems work. No interior lights, no keyless entry, no power door locks, no remote start, can't connect to the car via the app.
    I have to use the manual key to open the door, the push button start works and the car runs fine. With the car on, the dome lights work, the power door locks work, power windows work, all the driver assist systems all work. The HUD works but the position has to be reset every time the car is turned on and the clock always resets.
    The things that are not working regardless of car on or off is the infotainment system and the buttons on the screen and the QI wireless charger.
    I've checked all the fuses for continuity and can't find any issues. I would appreciate any ideas you may have on this one.
    49,399
    did you check both fuse boxes?
  3. Boefinator
    Yes both engine and kick panel.
  4. KMO
    KMO Senior Member
    1,521
    401
    Finland
    2023 Prius Prime
    Good puzzle.
    Looking at the wiring diagram, I vote for "10A ECU-DCC NO. 2" in the interior fuse box.
    Edit: Or, possibly, upstream of that, "25A D/C CUT" in the engine compartment fuse box.
    (D/C CUT is the fuse that's removed during shipping, leaving a car that can be driven on and off trailers, but doesn't drain the battery when not being driven. Dealer fits it during pre-delivery inspection).
    #4 KMO, May 16, 2024
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,919
    4,685
    Texas Hill Country
    There are fusible links that don’t look like fuses.
    Since you have devices not working, the straightforward technique is to get the schematic and trace the non-switched 12v for that device using a meter. Find it and you probably find all.
  6. Boefinator
    I'll put new fuses in both of those. Thanks for the idea.
  7. Boefinator
    The DC CUT fuse sure sounds like it would cause the symptoms I'm seeing. I checked fuses for continuity, but I could have missed it or just did it wrong. I'll have the car back tomorrow and post the results. I read the DC Cut fuse threads now and that sure seems like it. I appreciate the help.
  8. Boefinator
    I'm on my way to get a 25 amp fuse, but when in pulled I got other words that popped up regarding the collision avoidance and a yellow exclamation point. So I'm guessing that it's not the DC CUT fuse. I'll also try the 10 amp ECC NO. 2, but it looks good as well. Maybe a relay or a 12v sense circuit that is preventing 12v power going to these systems when the car is off?
  9. Boefinator
    Indoor fuse box, apparently I didn't check as well as I thought. Thanks for your help.
  10. Boefinator
    Winner Winner, Chicken Dinner! Your first guess was correct, ECU-DCC No. 2 restored the power and activated the locks, wireless remote, dome lights, and maintained all settings when powered off. The only thing that wasn't back was the infotainment system. So I figured if I missed the ECC fuse, maybe the 15 Amp Radio fuse I didn't check correctly and what do you know? It was a bad fuse as well. Thanks for your help!
    KMO likes this.
  11. KMO
    KMO Senior Member
    1,521
    401
    Finland
    2023 Prius Prime
    Now I just feel bad for not having enough confidence to stick with ECU-DCC No. 2. :LOL: I didn't spend the time to check what else DC Cut would have killed... :whistle:
  12. Boefinator
    It's all good just needed to drive to reset. Thanks again.
  13. ChapmanF
    15,494
    Is DC Cut even an actual fuse in a Prime? In gen 3 it's just a shorting jumper.
  14. KMO
    KMO Senior Member
    1,521
    401
    Finland
    2023 Prius Prime
    Apparently.
    Electrical Wiring Diagram says "25A" and shows it with a fuse symbol under "fuses", so I guess that's what it is. Also a fuse in G5, IIRC.
  15. RandyPete
    RandyPete Member
    172
    53
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    I think this post is in regardss to a 2017 Prius.
    Does a 2024 Prius Prime have a DC Cut fuse ?
  16. KMO
    KMO Senior Member
    1,521
    401
    Finland
    2023 Prius Prime
  17. RandyPete
    RandyPete Member
    172
    53
    2024 Prius Prime
    XSE
    Had trouble viewing that PDF like link. It seems to need a special app to view. Not willing to Install that app and agree to the use terms on my PC.
    #17 RandyPete, May 19, 2024
  18. rjparker
    7,919
    4,685
    Texas Hill Country
    Pdf
  19. RandyPete
    RandyPete Member
    172
    53
    2024 Prius Prime
    XSE
    Thank You, I downloaded that PDF and saved it.
    Viewed it. Saw the DC-DC CUT labeled item.
    Unfortunately my experience in reading and interpreting this info is very limited.
    PS: looks like the battery is depicted next to the FB/RB, like the 2022 PP, not the 2023-24 PP arrangement.
  20. KMO
    KMO Senior Member
    1,521
    401
    Finland
    2023 Prius Prime
    So what are you looking for? And what was the reason for the question?
    The point is that there is an amperage value shown for it - 30A - which makes it a fuse.
    The document is covering all model variants. That would be the 1.8L 2ZR-FXE position. The (*1) footnote is presumably noting the model variant.
    RandyPete likes this.
