Reverse question
Discussion in 'Gen 3 Prius Technical Discussion' started by ImeanGreen, Apr 18, 2012.
  1. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Does the gen 3 prius use electric motor only when in reverse? Reason I'm asking is that, I was in reverse and didn't see a rock that prevented me to move and keep pressing on the gas pedal and got no response and throttle response was zero even on the HSI screen. Had to move forward and back to reverse to gain momentum to go over the rock. Just a weird feeling knowing that the gas motor didn't even kick in even when pressing on the gas pedal. Has anyone experiencce this?
  2. Sabby
    Sabby Active Member
    295
    127
    SoCal
    I have not experienced a similar situation. To answer your question reverse is electric only.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    As mentioned, electric only. However, if you give it enough throttle, the ICE will start but not to add torque.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    All driving torque in reverse is supplied by MG2. If needed, the ICE will kick in to generate electricity via MG1, but the operation of the ICE will reduce the available reverse torque. This is because some torque from the ICE always tries to move the car forward, which fights against the desired movement in reverse.
    Tom
  5. ImeanGreen
    547
    73
    Somewhere out there
    Thank you guys. Just want some confirmation.
  6. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Electric reverse is way cool. The MG2 provides all the power that I need for reverse and there is no need to carry reverse transmission weight during most of my driving that is forward.
  7. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    My wife parked our Prius forwards down a steep narrow drive and the car would not back out because the HV battery was low and the ice kept running giving insufficient power to back up. I had to force charge the battery for a couple of minutes before it would reverse up the hill without the ice running. Lesson learnt.
  8. Matt M.
    Matt M. Member
    117
    San Francisco Bay Area
    Backing out of our driveway, I have to back up a moderately steep slope, and my Prius always feels very sluggish backing up that hill to get out of the driveway. It works fine, I'm not going to get stuck, but the first time I tried it I was a little surprised.
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    How steep a hill can a Prius back up with a good charge on the batteries?
  10. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    My inlaws have a steep drive I back out of several times a month. Prius throttle almost on floor and we slowly go backwards up the drive. Really weird. It makes it but very slow. If I loaded it with (4) 200 lb guys I bet it would barely make it (my wifes and 2 daughters weigh less than 120 lbs each).
  11. RichardAK
    RichardAK Member
    121
    Fairbanks, AK
    Interesting as I have a pretty steep driveway and never had an issue backing out. It doesn't strike me as very slow. If there's snow on it, backing out is the only way (puts more weight on the front wheels).
  12. Mendel Leisk
    42,170
    That sounds almost like the Volt.
  13. qbee42
    18,058
    3,081
    Northern Michigan
    The Volt has several modes of operation. The one you are thinking of is a serial hybrid mode, where the prime mover (ICE) powers a generator which powers an electric motor.
    The Prius often operates in this mode, but only partially, as there is also a mechanical path from the ICE to the wheels. In reverse this mechanical path fights the serial hybrid path, greatly reducing available torque and efficiency. Fortunately we don't spend much time driving in reverse.
    Tom
  14. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    That's correct, when you're going backward, theGen 3 Prius is like the Volt, but for a lower price.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    How fast will it go in reverse on a flat road, would I be able to throw a J-Turn to escape baddies ?:D
  16. qbee42
    18,058
    3,081
    Northern Michigan
  17. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    :rockon: Now I just need instructions on how to J-Turn with a foot operated parking brake. :car:
  18. ralleia
    ralleia Active Member
    386
    137
    Omaha, Nebraska, United States
    Whoa, that's really good to know!
    Thanks for pointing that out. It's really quite clever to do away with the reverse gear to simplify the transmission.
    Hmmmm...mentioned this to DH and he doesn't like it at all. Thinks that it will be a severe disadvantage getting unstuck in snow.
    Does anyone have experience with getting stuck in the snow in a Pri?
  19. qbee42
    18,058
    3,081
    Northern Michigan
    I'm from Northern Michigan. I have experience getting stuck in snow with nearly every type of vehicle imaginable: cars, trucks, Jeeps, snowmobiles, airplanes, and even boats.
    The Prius isn't a Jeep, so don't expect it to go through snow like one. On the other hand, it does as well as any front-wheel-drive car as long as you put good tires on it.
    Rocking it out of snow is more of an issue about traction control than rear torque. It will rock, but you have to work harder at it than you do with a manual transmission. I do think it's easier to rock than a normal automatic.
    Tom
  20. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    While that looked real, I suppose you could make it look like 100MPH in reverse by running the video backward. I look the direction I'm traveling and drive pretty slowly in reverse, but that video has me wondering what the Gen 3 Prius speedometer reads at 20 MPH, or any other speed, in reverse. Is it pegged at zero, or does it read 20? Does this discussion remind anybody of the vintage Ferrari in 'Risky Business?'
