reverse warning beeps
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by recycled55, Dec 30, 2019.
  1. Mendel Leisk
    42,345
    You need the Dr Prius app and bluetooth dongle plugged into the OBDII port. Several dongles are recommended on the Dr Prius site; I went with Carista and it's worked fine ("Carista OBD Adapter for iPhone/IPad and Android New" is the description on the box).
    ScanGuageII I'm not sure if it can do similar, maybe with XGauge programmed in. It's a different item, more for display of various functions not normally shown, coolant temp, rpm and so on.
  2. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    You cannot cancel ONLY passenger side beep.
    I tried successfuly with reverse beep and ALL seats beep.
    I used Dr, Prius app and interface OBDLink LX/MX (in attach)
  3. Jordanhiggins2002
    94
    39
    Socal
  4. Jordanhiggins2002
    94
    39
    Socal
    So I ordered the Carista and loaded the app and now to save my changes I have to pay $10 for one time use or a pro for $30 a year.
    this is ridiculous!
  5. Mendel Leisk
    42,345
    Which app is that? Carista app? Just use the Carista dongle, not it's app. Dr Prius is lifetime if I'm not mistaken.
  6. Jordanhiggins2002
    94
    39
    Socal
    I bought the little Carista that you plug in and when I went to change the reverse beep and click save it automatically sent me to subscription crap.
    Is there another way?
  7. Mendel Leisk
    42,345
    I downloaded/installed dr Prius, then plugged in the Carista, started the app, and it detected the Bluetooth signal. Forget the exact steps but not hard.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    The last I knew, if you bought the Carista device, you got either a week or a month free use of the app. You simply do what you need to do with it and then cancel the subscription unless they changed how they do things. I REALLY hate renting software. It's like ransomware but it's for the apps rather than the data and they keep making you pay and pay and pay.
    Or, as @Mendel Leisk said, get the Carista device and buy Dr. Prius. Dr. Prius won't let you customize everything but at least you can change the reverse beep and a few other things.
    If you have an old laptop, for the same price, or less, you can get Techstream and a dongle from Ebay or Amazon and then you can do pretty much everything a dealer can do.
    I have all three options.
  9. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
    Hello all just wanted to jump and say I have a 2010 and the Carista app and paid the one year service.
    It is not worth it specially when I found a prius app that did the same thing as far as turning the reverse beep off.
    You can use the carista Bluetooth adapter with other OBD2 apps like Dr. Prius and it will work.
    The Carista however does offer customizations that others don't.
  10. Jordanhiggins2002
    94
    39
    Socal
    Used the Prius app and it worked out great. Reverse beep is just a single when you put into reverse and no seat belt light beat.
    thank you everyone for the help. Awesome!
    Mendel Leisk and jerrymildred like this.
  11. Jordanhiggins2002
    94
    39
    Socal
    many cool custom stuff you can do with the app?
  12. bisco
    52,849
    not really
