REVIEW: Hymotion Battery Plug-In Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by TheForce, Aug 12, 2008.
  1. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    The Force,
    What is the difference between the coolant hack versus the 52 MPH hack? I use the 52 MPH hack, but I'm not familiar with the coolant hack. When it is this cold the 52 MPH hack won't allow you to draw too many amps and the car is very sluggish on EV.
    ---Kent
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    The coolant hack fakes the coolant temperature to stay above 159F. When you get above this temperature the car will go into EV mode on its own when you reach 35mph.
    How are you doing your 52mph hack?
  3. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    I contacted Carolyns Luscious garage for the info and switch. Works very well except in the extreme cold you have no power. It does cause dash to light up like Christmas, but the codes are easily cleared. Only disadvantage, you must restart car to get engine to start again.
    ---Kent
  4. PeakOilGarage
    PeakOilGarage Nothing less than 99.9
    334
    Pacific Northwest
    Yes, cold weather is definitely affecting results.
    Grill blocking is a big help though. We have been around 30-40 degrees in Seattle. I am still maintaining my 99.9+ mpg.
    I was really struggling before the grill blocking.
  5. Flying White Dutchman
    4,376
    314
    so you get some kind of button and a control board?
    what did you pay for it?
  6. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    I got a push button that fit beside the Hymotion on/off switch and a diagram of which wire to cut and run to the switch. I paid for the knowledge not parts.
    ---Kent
  7. jessebismarcknd
    jessebismarcknd New Member
    29
    Wilton, ND
    Do you have a switch to force EV mode with your Hymotion? I would love to have one on mine, but have heard conflicting reports about whether it supports it or not. I have heard that some of the newer Hymotions do not (that it overrides it) but some of the older ones do not.
  8. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I have a manual EV button. You can install the manual button but you will have to disable the Hymotion wire so the manual button and Hymotion pack will not conflict.
  9. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Just filled up today. 166MPG and 1691.3 Miles. last fill up was 2008-12-29. :D :p
  10. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    TheForce,
    It is obvious that with the Hymotion mod installed, the addage,
    "Ultimately all the motive power comes from the gas tank," does not
    hold true. To reach the MPG figures you're getting, a lot of motive
    power comes from the extra battery. I know that MPGs are a function
    of route and topography among other things. In your case, it would
    appear that your particular daily driving needs fit nicely with the
    Hymotion output capacity.
    In the stock Prius, the gas engine is assisted by the HSD/HV battery.
    In your car it would appear to be the other way 'round.
    I looks to me that in your particular driving conditions your Hymotion
    equipped Prius has become essentially an electric car assisted by a
    gasoline motor. It is natural then to ask, why aren't you seeing 200,
    300, or even higher? It's in the math of course. When you're using as
    little fuel as you do, even a short engine run, say to cover a mile at 50
    MPG would greatly inflate the denominator in the miles/gallon
    calculation.
    At any rate, many thanks for your on going reports on your experience
    with the Hymotion mod. Despite my leaning towards getting something
    like the iMiEV when they are finally available, your story keeps me
    coming back to considering the Hymotion as a practical alternative
    that is here now.
    Why don't I jump on the Hymotion? There is a possibility we will need
    a second car in the forseeable future, and I'll need the doh-ray-me.
    Keep up the good work out there on the cutting edge. :rockon:
  11. TheForce
    3,461
    537
    Wheelersburg, Ohio
    The reason I wont see or may not see anything above 200MPG on a tank is because of the time it takes me to travel 2000+ miles. During that time I may take a long trip that goes well out side the range of the Hymotion battery. I do however get 200, 300, and even 400 MPG on my trip to and from work according to my ScanGauge. Its those longer trips that knock me down to the 100-160 MPG range. With any luck this next tank will be my 2000+ mile 200+MPG tank. Only thing holding me back is my trip to the Green Drive Expo in July. By my calculations I be just shy of 2000 miles by then.
  12. PeakOilGarage
    334
    Pacific Northwest
    And that was during cold weather temps. I suspect you will do even better this summer. Great job !!! :rockon:
  13. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    All very interesting and thanks for the detail Mr. Force :)
    Two comments/questions:
    1) You CAN NOT force EV with the hymotion engaged?? Bummer. It would be a great EV only car for those with 10 to 15 mile commutes if you could.
    2) The charger for the Hymotion is IN the spare tire well. Hadn't realized that before. I wonder how many kWs they could fit in a battery that sat in the spare tire well with an external charger for those that only charge at home (or maybe portable enough to toss in the back for charging at destinations.
    OR: maybe how many MORE kWs the Hymotion battery could hold if the current total volume was batteries, not batteries and charger.
    OR: lift struts on the current battery (without the charger) so you still have the spare tire. Hope to never need it but don't want to leave home without it ;)
  14. TheForce
    3,461
    537
    Wheelersburg, Ohio
    You CAN force EV with the Hymotion. I do it all the time. You just have to have the button installed.
    I strap my spare tire on above the battery. I don't carry around much cargo so that works well for me.
    I don't know the answer to you other questions.
  15. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Looks like someone from NC will be making rounds in OH to upgrade the Hymotion software. My upgrade is scheduled for Tuesday morning. I'll report back and let you know how it went.
  16. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    Why and what are we upgrading. My Hymotion seems to be fine.
    ---Kent
  17. TheForce
    3,461
    537
    Wheelersburg, Ohio
    The guy I talked to said it was a software update. I did not ask why. I'm guessing its to help fix the 12v issue and give us the CARB required start up. I'll try to get more info on Tuesday. Have they called you yet or have you had yours updated?
  18. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    Strange, if you have a phone number for the person please send me it. I have not had any problem since I put the L5 Battery Booster on. If it only updates for CARB, I'd prefer not to have it, unless other benefits are stated.
    ---Kent
  19. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    ????'s
    I drive 80 miles a day. mostly 80% of speeds under 35mph/10% hwy/10% 45mph.
    going to own the car for the next 3 yrs or 150k miles (at 41k now in one year)
    drive about twice a mo. out of town (around 600miles hwy)
    ok now the ???
    1. Is this a good choice for me?
    2. can i plug it in between trips ( car avg about hr off time between jobs, then drive 10 miles to next)?
    3. do i turn it off for those long hwy trips or leave it on?
    4. at what speed does ice turn itself on ( i do have ev mode and and do now how to use it)?
    currently i can avg (before the new tires) 57mpg with EV, EBH, and Grill block. i dont see myself has a hypermill driver ( if traffice is going 55mph in a 45mph zone i go with the flow).
    without those small mods i can avg 49mpg.
    thankyou
    mike
  20. zcat3
    zcat3 New Member
    117
    35
    SF Bay Area
    With only three years expected ownership, I doubt you would recoup your investment unless gas goes to $4 or more per gallon again. The Hymotion pack is expected to last 100,000 miles at full capacity and then start to decline from there. Nobody really can say for sure, though, since we are still waiting for real world results.
    That said, you would probably at least double your mileage with the Hymotion. I just did a quick calculation, and figured if gas averages $3 per gallon over the next 3 years, you drive 150,000 miles, and the Hymotion doubles your mileage, you would save $4,000 in gas (keep in mind that this is offset by energy costs if you have to pay for all the kWh you use). I suppose you may get some money back on a higer resale value, but I doubt it would add $6000.
    Your commute does sound pretty ideal for the Hymotion. The Hymotion pack when fully drained needs about 4.5 - 4.8 kWh to charge back up. The pack charges with a standard 120v outlet at about 1 kWh per hour, so if you could plug it in for 4 hours during the day you would almost have the ability to go through 2 full charge cycles in one day, whch should get you 60 - 80 miles in Hybrid mode or 30 - 40 miles in pure EV mode.
