REVIEW: Hymotion Battery Plug-In Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by TheForce, Aug 12, 2008.
  1. TheForce
    3,461
    537
    Wheelersburg, Ohio
    John is right. Its going to be a while for complete details. I will be posting my commute information as soon as I get some elevation data and some more trip and charging data as well. I should have this information ready by Wednesday but don't hold your breath. This review wont be finished until I fill my tank up with gas and by my calculations that wont be until the middle of October. Maybe even longer. Actually it will have to end October 12th as I will be taking a long road trip to the Georgetown Toyota plant. Thats if I don't take a long trip before that.
  2. Stefx
    Stefx Member
    336
    In the same perspective you adopted, you driving a 2008 Prius makes no economical sense at all, you should be driving a used Toyota Echo instead.
    Now you're going to pull some "but" arguments, stating that choices can't be made purely on one single criteria (money).
  3. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I got 237MPG on my way to work today. I tried a little detour to see if I could get a little more EV only out of my commute to up the MPG. Looks like the 235MPG area will be about the best I can do without a coolant hack.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Thanks for the continued updates...Can you give us a rough idea of what you commute involves...distance, speeds, traffic, stops....
  5. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    i wonder if using fuel stabilizer for those who use ev mode a lot would be a viable option, i heard they work great for fuel that is in storage (up to a year i heard). bottle covers 70 liters i think and costs like 13 bucks.
  6. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Just got home with the ScanGauge showing 516MPG. :D The reason I got that was because there was no one behind me and I was able to do a steady 30mph all the way home. That was until about a mile a way from my house some one got behind me. If no one got behind me I could have had a 1000MPG trip home but NOOOOOOOOOOOO some one just had to get behind me on my last mile. :mad:
    With this long trip in mostly EV mode I now know if all the roads I took to work were all 35mph I could get to work and back and possible another trip to work on a single charge. My guess right now would be that you can do about 30 miles in all EV mode if your easy on the go pedal. I cant wait to do an all EV mode test.
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The attached file is the results of this year's 21st Century Automotive Challenge. The Run to the River for PHEVs is described on page 2 & pages 9-10. Since the drivers of stock Prius were getting 60+ mpg the phev Prius performance seems disappointing especially since it was over 50 minutes late.
  8. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    omg. I thought 125 was gonna be great but 250? That 500mpg must be an anomaly, yes? I cant wait to hear about your October road trip!
  9. Flying White Dutchman
    4,376
    313
    :mad:laws need to be changed
    max speed 30mph everywhere:D
  10. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I had to work today so my highway test has been postponed until tomorrow.
    On my way to work I was able to get 211MPG.
    I think since the SG still reports .01GPH of fuel burned when in EV mode that my numbers wont be very accurate from the SG. When not moving and not burning fuel I can see my MPG drop every few seconds. :(
  11. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    Can you describe your commute to work. Average speed along with terrain.
    ---Kent
  12. zcat3
    zcat3 New Member
    117
    35
    SF Bay Area
    Yep - obviously if you have a 10 miles commute with speed 30 and under, you should get infinite MPG if you have an EV button and stay on all electric. Is there a reason you won't post your commute details? Saying "I get 500 mpg" without any other data tells us absolutely nothing.
    For those who want to see some real world data on the Hymotion performance, you can look at the Google tests going on here: Google.org
    They have 4 plug-in Priuses (using the Hymotion pack) and a plug-in Escape. So far, the 4 Priuses are averaging close to 70 MPG in Bay Area driving, which involves lots of freeway driving. You can click on each car to see the data for each day.
  13. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    With the extensive write up done so far, it is easy to understand why he has not responded yet.
    ---Kent
  14. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    great link, TY for the info... but you cant be serious when comparing their data gathering to Jay's... give him time, hell, he aint had the thing a week!! he has already said it will take several weeks to burn thru his tank of gas. until then, we wont know much of anything.
    what do you want, a report on every pip as it disappears?
    right now, i will take any info i can get...better than waiting a minimum 2-3 weeks for a full report on a single tank of gas
  15. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Just some costs to consider. He used about 6 kw-hr to fully? charge the battery. Here (Edmonton Alberta) it costs just under $0.10 per kw-hr. So think of it as $0.60/cost per gallon= perhaps 1/4 to 1/5 of a gallon. Or $0.60 per charge. If that takes you, in effect, 100 mi, (we have to get confused due to the engine running above 30 MPH) that could be considered the same cost as burning gasoline at up around 500 MPG. Of course I haven't factored in the hardware cost.
    I wonder how the govt. is going to recover road tax. ;)
    It -is- funny how our perceptions change, isn't it? I now get depressed when I see my MFD indicate I'm over 4.8 l/100 km. The anti-Prius -NEVER- got under 13 l/100 km! It was often above 15 l/100 km. :)
  16. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    there is some obvious conversion factors that must be applied, but on Zenn, if taking same amount of energy as a gallon of gas, the Zenn will travel 254 miles on electricity with same amount of energy
  17. zcat3
    zcat3 New Member
    117
    35
    SF Bay Area
    I'm not expecting anything like the google data, just some basic commute info to tie to the mileage claims. If you look at the google data, you will see some trips with mileage well over 100, but this is not the norm. Interestingly enough, one of the Escape PHEVs is averaging close to 50 MPG and is doing lots of long trips and freeway driving - seems like the overall mileage improvement is better with that module than with the Prius module (note that the Escape pack is an 8 kWh pack).
  18. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    WoW Jay, I just saw this thread!! Congrats!! and what a nice write up.......... Man, that's sure a nice present to give yourself...... Please keep us updated as I have been considering this addition as well, but I'm with Evan, I may wait to see how long I keep my '06, and/or trade for a new Prius....
    dude, I'm extremely jealous!! sweet............
    dave
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    very valid questions, no doubt... i think we will get the rundown soon.
  20. Flying White Dutchman
    4,376
    313
    he wy don't you make the same video like this one
    or
