Review of my yellow 2023 XSE Premium Prime
Discussion in 'Gen 5 Prius Main Forum' started by bumblebee_prime, Jul 31, 2023.
  1. bumblebee_prime
    bumblebee_prime New Member
    Vancouver
    2023 Prius Prime
    XSE Premium
    True that they are not the same but the standard mirror is fine for showing things directly behind you and the 360 camera has a wide enough view around the car (Surprisingly wide actually) that you can see anything on the ground/below the view of the review mirror. If you don't have the 360 camera then I think it would be much more useful.
    Also something that I just discovered today (That might be common I don't know??) is that for the cameras, after you reverse and use the backup camera it will show you a forward facing camera too!! So lets say you're backing up, it displays the backup camera (And 360 camera if you have it) and then once you put it back into Drive it shows a forward facing camera until you go past a certain speed. That way you can see whats directly in front of your car beneath the bonnet (think like toys on the ground or other small obstacles. Maybe not the craziest feature but I can see it being useful for some. It's nice to glance at it really quick to make sure.
    And thank you! I will try putting my phone like that next time
    Thank you so much! It really is exceptional. Also nice to see a fellow Canadian, hello from the west coast.
    I just responded to someone else's comment regarding me acquiring the car (TLDR: waiting 3 weeks, no preorder, yes I'm very lucky lol).
    I have tried my phone as well as a few others, most did not charge, some did but got very hot. I also posted about this on reddit and it seems everyone is either in team no charging or team it works but its very slow and heats my phone up. Pretty unfortunate as I was looking forward to using it, but there are so many USB c ports on the car and they charge my phone so much faster/cooler that I just use them if I need a charge, not the biggest deal.
    #21 bumblebee_prime, Aug 1, 2023
    Maxwell61 likes this.
  2. flarecde
    flarecde Member
    56
    68
    NY
    2023 Prius
    Limited AWD-e
    I've seen a lot of people complain about heat issues with the wireless charging. I left mine (iPhone XR) in there for a four hour drive and it quit working near the end of the trip. Took a bit of time to cool down and work again. I'll try out putting it in askew, that has promise.
    Given that wireless carplay is also [random animal excrement], I just leave it plugged into the USB in the tray up front with a 1' cable.
  3. bumblebee_prime
    Vancouver
    2023 Prius Prime
    XSE Premium
    Wireless carplay has worked flawless for me so far (fingers crossed). I usually just plug my phone into the charger slot in the center console and leave it in there, or if my battery is close to full I just leave it in my pocket
  4. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    You can also use a USB plug in the console box and route it to a phone in the slot. A slight indentation between the box and the phone slot lets you close the console box completely and enable the cable to run free. I have extra black USB-C to Lightning cables from my computer purchases. I used one of those, and it's practically invisible.
    daisy555 likes this.
  5. bumblebee_prime
    Vancouver
    2023 Prius Prime
    XSE Premium
    Yes! I saw that indent in the molding, very helpful
  6. Yvrdriver
    Yvrdriver Member
    47
    42
    Vancouver
    Wow, good for you! Glad someone was able to bypass the long wait. 2 years is what I've heard...
  7. Hammersmith
    Hammersmith Senior Member
    2,315
    2,338
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Repeated public service announcement:
    If your phone gets hot in the wireless charger, consider going into your phone's settings and disabling fast wireless charging. Your phone will still charge in the slot, it will just charge slower but won't get nearly so hot in doing so.
  8. Tideland Prius
    16,553
    Ahh no worries. Should be fine. It’s the same chassis as the Gen 4, right? It’s pretty decent for a compact car.
    Note that B mode in hybrid mode will actually increase fuel consumption because it won’t let the engine shut off. It’ll make no difference in EV mode of course (just increased off throttle regen but just remember to shift to D once your range is depleted).
  9. MarkOlin
    MarkOlin Member
    78
    39
    Buffalo, NY
    2020 Prius Prime
    Good review.
    You mention no problem with headroom? I've never sat in one yet but from the outside it looks tight. Looks like the top of the windshield is close to your head. From what I read, overall head room is just a bit over 1 inches less. Just wondering if people notice the lack of headroom moving from the previous generation
  10. daisy555
    daisy555 Senior Member
    1,715
    708
    CT
    This will give you some perspective. : } He looks like a giant next to this yellow Prius. There are definitely some tall guys on Prius Chat who are pretty comfortable but depends how tall you are.
    The windshield is deceiving. I was initially a bit freaked out by it. I’m only 5’ 3” and felt a claustrophobic because I have to put the seat all the way up. The windshield doesn’t feel so raked when driving and after a few test drives I’m getting used to it.
    #30 daisy555, Aug 5, 2023
  11. aforkosh
    413
    272
    Oakland, CA
    2023 Prius
    I'm 5'9" and have the back of the front seat pretty close to vertical. I've no issues once I'm inside the car. However, I have learned cock my head toward the rear of the vehicle when entering the front door and to bend forward when entering the rear.
  12. Downrange
    Downrange Active Member
    372
    211
    2024 Prius Prime
    SE
    Thanks for a great review! One qx: what roof? Glass or solar?
  13. Koolfreak
    Koolfreak Junior Member
    61
    St-Rosaire, Québec, Canada
    No solar roof in Canada. I wait for a yellow too. I made my deposit on November 21th 2021. No news about when it will arrive.
  14. Louis19
    Louis19 Active Member
    392
    369
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    OMG c'est long en Ta....(it's a very long wait):eek:
  15. Koolfreak
    61
    Mets-en!
    If you can take some clear pics of your yellow Prime, I want to see what yellow maximum look like! Thanx
  16. Louis19
    392
    369
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Have not seen one yet ! and I don't have one either !.....very happy with my 2022 prime ugrade and not looking to go with the 2023.
    regarde mon profil;), ton profil indique une Prius C 2012 !
    #36 Louis19, Aug 6, 2023
  17. Techelet
    Techelet New Member
    Kansas City
    2023 Prius
    Fantastic review! Thanks. Just got my 2023 Prius XLE. I so wanted that yellow, but couldn't get it in any of the more interesting colors or even the light interior. And I've never seen a Prius Prime in Kansas City - they only have them as special orders, so no chance to test drive or even look at one. You're probably the coolest car on the road! Congrats.
  18. Maxwell61
    Maxwell61 Active Member
    392
    241
    Italy
    2024 Prius Prime
    XSE Premium
    Congrats for the car and the review!
    I'm not so lucky as you and my yellow EU equivalent XSE Premium will arrive on Jan 2024...
    Differences with the EU Gen 5 are the Solar Roof standard on the top trim and the absence of the Wireless charging on all trims.
    My question is about the AHS (Adaptive high-beams) matrix headlights: have you AHS in Canada? Have you tested it? On EU top trim are standard equipment.
  19. bumblebee_prime
    Vancouver
    2023 Prius Prime
    XSE Premium
    Yes we do have AHS in Canada, they work well, but are pretty sensitive, they won't turn on the high beams even if there aren't cars on the road until it's fully dark which is strange. I would only use them on like back country/canyon roads, but for that they are perfect
  20. KMO
    KMO Senior Member
    1,953
    678
    Finland
    2023 Prius Prime
    Do you really? I don't see it in the Canadian manual. I think you're describing the Automatic High Beam (AHB), rather than the Adaptive High-Beam System (AHS), which messes with light distribution patterns.
    AHS is fitted to only the PHEV in Japan, and it's in the top two of three (PHEV) trim levels in Europe.
    Japanese HEVs and bottom Europe trim get AHB.
    (Really confusing acronyms and names here... And they use the same button...)
