Reving after releasing gas.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by jamz111, Sep 15, 2014.
  1. craig donnelly
    craig donnelly New Member
    massachusetts
    2016 Prius c
    This might be my issue. after . I have a 2016 prius c. After it runs 45-50 minutes . when i release the gas pedal it revs a few seconds. . once this starts the car says EV is not available at the moment. If I shut the car down for 4 hours it goes back to normal . started a few weeks ago. I will check the fan. went to the dealership and they didnt see anything . I also called Toyota about it and they logged a case but had no info .
  2. craig donnelly
    massachusetts
    2016 Prius c
    you can break those clips easy. less than 2 bucks from the dealer. they should add this vent cleaning to their maintenance service every 15K. Talked to the dealer and also Toyota direct and they said they have not gotten complaints about it . I filed a complaint so it is on record with them . i have 2016 prius c and the engine rev along with it not going into EV mode started 2 days ago . I cleaned the battery air intake vent and it now is working properly . Not hot enough to set the battery alarm off so that is why diags dont pick it up. Eventually you would get the over heating light. 100% sure this is the issue. Thanks everyone . Saved me a few hundred bucks and aggravation.
  3. craig donnelly
    massachusetts
    2016 Prius c
    Fan cleaning fixed it . thanks
  4. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    I definitely think this is the case. I was having the revving issue in two contexts and this is consistent with the changes I've made.
    First, I've had the Toyota techs tell me my car has too much dog hair and that's coincided with the revving issue. Thinking back, it's certainly correlated with the battery status and temperature.
    Second, my hybrid battery recently failed and I had to get it replaced. I drove around 100 miles with just the ICE engine and noticed that the car was doing the revving thing every. single time. I drove on the freeway and noticed it happened at all speeds and regardless of incline or decline. Then, I changed my battery to a brand new one and the issue went away immediately.
    Both of these suggest to me that the revving is done to protect the battery from high temps, and overcharging, AND to make it so the driver still feels like the car is slowing down around the same amount as it would if it was capturing energy. In other words, the car wants to make it feel like its engine braking always (either by electric capture or ICE engine braking) whenever letting off the gas. All this to say, I'm confident the overrevving is usually nothing and most folks need to just vacuum their car, make sure the vent can get plenty of air, and clean the vent.
    Also, the vent goes from behind the driver seat, under the passenger seats, and out through the right side of the trunk. Look for the little vent on the right end and make sure that isn't blocked too!
    As an aside, I bought a Lithium battery to try that out as rebuilds are crappy and the original ones are more expensive (and older technology). So far I love it!! I have noticed that the electric-only range is longer! Might just be my perception, however, since I am going from a busted Nickel battery to a brand new Lithium battery so not a true apples-to-apples comparison.
  5. robinredd1
    robinredd1 Junior Member
    52
    Salem illinois
  6. robinredd1
    52
    Salem illinois
    I have been doing with this for over a year somewhere on my car I have a wire somewhere due to I'm not sure exactly what is causing it myself but there is a drain a very slow drain on my 12 volt battery and every time the 12 volt battery gets low the car starts revving up when I release the gas charge the battery and everything's fine a okay there's the solution 12 volt battery charge it up or buy a new one and it's gone it goes away that's it that's it solved salt
  7. robinredd1
    52
    Salem illinois
    I've gone through this for a long time replace the 12 volt battery or charge it up and it goes away that's it I learned I read somebody else's post a long time ago about that and sure enough it fixed my car and that was it anytime my car starts getting a low 12 volt it starts ripping up when I release the gas so just charge it or buy a new one and your problem solved
  8. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    Sorry, it's hard to follow what you wrote without punctuation. Are you saying your battery is getting ripped up on each charge?
  9. ChapmanF
    19,027
    looks like 'ripping' ⟹ 'revving'
