Revisiting small 12v heater discussion
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Jan 26, 2015.
  1. GregP507
    GregP507 Senior Member
    3,002
    481
    Two things here; I agree that further gains may theoretically be possible (watch for the Gen 4) but I don't have the engineering skills (the numbers) to achieve it, and I question anyone who thinks it's just as simple as running the engine for shorter times. We simply have to assume that Toyota knows what they're doing.
    Exactly.
  2. markabele
    5,084
    1,782
    Nebraska
    Greg...do you think it's somehow possible that the best engineering is undermined by cost saving techniques? They are, after all, a business trying to make money. I think the point most of us are trying to make here is that even if it cost a little bit more, most of us would pay for a built in electric heater.
    52,804
    i think this discussion is somewhat polluted by a lift back mindset. i would love to find out more about the 600w heater. that's half my wifes blow dryer on low, and you that that would be detectable inside a car at 20 degrees.
  4. GregP507
    3,002
    481
    Maybe you would; maybe I would, but the point is that Toyota made the judgment call. Is it possible that the electric-heater idea may have a fatal-flaw that you may have overlooked?
    I'm no engineer, but I know it takes a lot of watts to blow a small amount of warm air.
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    As Chap says, lots of ways to come out ahead, depending on the circumstance. Consider mine:
    • I do not want to use the usual cabin heating in my (v)agon for the first 10 minutes of a drive on a cold winter day. The advantage to me is quicker ICE warm-up which lets me P&G and brings the ICE up to efficient operating temperatures earlier**. A 40 watt blanket for 10 minutes costs me under 7 Wh of electricity, which is about 0.00060 gallons* of fuel.
    GREAT DEAL
    *Assuming 36% thermo efficiency of the ICE, paid back when the engine is nice and warm.
    ** Figure a 5 minute savings of driving at 50 mpg rather than 25 mpg. If the 5 minutes is 2.5 miles, the fuel savings is 0.5*2.5/50 = 0.025 gallons.
    #65 SageBrush, Feb 17, 2015
  6. GregP507
    3,002
    481
    Value choice. If you want to forego interior heat for a few cents off your fuel costs, and that gives you satisfaction, you apparently win both ways.
    Personally, I choose to consider the bigger picture, and it's not worth all the agonizing over small things for small potential gains. I derive more satisfaction from driving a vehicle which was designed to be more efficient under normal driving.
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    Correct -- value choice.
    The engineering and physics, however, are pretty straightforward.
  8. GregP507
    3,002
    481
    You can't argue with the economics of a bicycle, either. You can always trade comfort for economics; you don't need engineering or physics for that.
  9. SageBrush
    11,627
    2,533
    Southwest Colorado
    We are not discussing bicycles, we are discussing use of electric heat rather than ICE heat.
  10. GregP507
    3,002
    481
    But that's the logical endpoint of your argument. At some point, it looks like a lot of time, expense and discomfort just to save a little bit of fuel.
    My Dad always said, "Why spend $10 to save $1?"
  11. bisco
    52,804
    it costs me nothing to not turn the heat on, and you can take that to the bank.
    markabele likes this.
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    And it costs me less (in pollution, money etc) when I use less. Isn't that amazing ?
  13. bisco
    52,804
    it's complicated, but worth the effort.:)
  14. GregP507
    3,002
    481
    It costs much less to ride a bicycle.
  15. bisco
    52,804
    your insight amazes me.(y)
    SageBrush likes this.
  16. GregP507
    3,002
    481
    It keeps me from being distracted from the bigger things by the tiny things.
  17. SageBrush
    11,627
    2,533
    Southwest Colorado
    Another value judgement.
    Lots of PiP owners, Bisco included, wonder why they paid thousands of dollars for a plug-in when the damn ICE runs for short winter trips.
    I am happy to save small amounts: they add up. If they were multiplied by the 100s of millions of people who have a choice, they would be huge amounts.
  18. bisco
    52,804
    all i have is tiny things.:)
    retired4999 likes this.
  19. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    I think PiP has electric heating element. I have seen ICE running for heat and a battery pip dropped. So it was using both for heat.
    Co-generation is what allows PiP to be so efficient with either fuels. A regular Prius (rated 50 MPG) turns on ICE for heat and PiP is no exception.
    Yes, short trips that need heat stinks. But how often do you really run into those?
    Using electricity for heat is also a bad idea, especially from the battery.
  20. retired4999
    2,652
    627
    Eau Claire, Wi.
    Oh! So sorry!:D
