Revisiting Stuck Throttle Litigation via Hack-a-Day Website
Discussion in 'Gen 2 Prius Main Forum' started by PriusCamper, Oct 30, 2022.
  1. PriusCamper
    PriusCamper Senior Member
    13,459
    5,430
    Pacific Northwest, USA
    Posted this morning at: https://hackaday.com/2022/10/30/recreating-the-stuck-throttle-problem-on-a-toyota/
    "[Colin] is recreating one of those failure modes by introducing an electromagnetic pulse at a specific point on the vehicle’s computer. In the real world, this could be caused by certain forms of EMF potentially including cosmic rays. This introduces a memory fault which the computer doesn’t seem capable of recognizing or clearing. With the right set of circumstances that [Colin] can reliably produce, the computer eventually will drive the throttle fully open, and the condition can only be corrected by power-cycling the vehicle’s computer.
    ...Toyota is adamant that these problems have been successfully swept under the drivers-side floor mat, but according to IEEE and other professionals in related industries such as avionics, the passenger vehicle industry has done remarkably little to ensure enough redundancy in these systems to account for these types of failures."
    JahT likes this.
  2. pasadena_commut
    pasadena_commut Senior Member
    3,063
    951
    Southern California
    Is the claim that putting the transmission into neutral will no longer work? That is supposed to throttle back the motor. (All hypothetical for me, I have only ever put it in neutral while moving for a few seconds, to scrape rust off of brakes that were wet the night before, at a very low speed.)
    Hypothetically I suppose it might be possible to flip enough bits so that the software in the relevant computer goes into a non-responsive loop. However, I suspect a more likely outcome would be before that happens one of the many safety checks would notice that much was awry and it would throw a code and a red triangle, and possibly even putting the car into a limp or limited throttle mode.
    PriusCamper likes this.
  3. PriusCamper
    13,459
    5,430
    Yes, there's several ways to shut the car down during unintended acceleration... However in the world we live in people don't think clearly during life threatening situations and freeze up and don't know what to do. I'd argue that the majority of major car accidents is because people freeze up with fear when things go wrong. We could get a lot of bad drivers off the road if a driver's license test included a simulator to test if a person's brain and body can keep functioning when faced with a dangerous situation. What's more how many people are taught that sudden turning of your steering wheel when you're driving fast is often more dangerous than than the accident they're trying to avoid, especially if you're fish tailing. People don't understand the limits that if ignored turn a more minor collisions into a deadly accident.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    Meh
    Doesn't keep me awake at night.
    Already know that most people on the road don't know how to drive. It merely becomes more apparent when an unusual circumstance arises (such as poor weather or "emergency" situation).
  5. PriusCamper
    13,459
    5,430
    Yes... The priority is to protect yourself from life threatening stupidity and there's a greater selection for that than ever before. But more to the point if your accelerator pedal is not directly connected to the throttle then you need way more safety-based redundancy than is currently required or it will cost you more than a billion: Toyota reaches $1.2 billion settlement to end probe of accelerator problems - The Washington Post
  6. JahT
    JahT Member
    145
    77
    So the dealer didn't need to take a hacksaw to our accelerator pedal? I knew floormats were not ever going to be a problem, but the wife preferred doing what the dealer and Toyota said.
  7. bisco
    52,849
    i refused both services, utter nonsense
    JahT likes this.
  8. PriusCamper
    13,459
    5,430
    Nonsense is often the best way for corporate lawyers to make problems go away. Like remember that Lawyer who won a $14 billion dollar verdict for indigenous people in Ecuador who had their land destroyed by Exxon? That was solved by Exxon hiring a team of 400 lawyers to throw so much nonsense at the case that case that it turned into the ruling being overturned and the US lawyer who represented the tribe being placed on house arrest.
