Revolutionary Better Prius
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by inferno, Jun 24, 2013.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    . I am working on the perpetual motion machine. Seriously, should somebody produce a machine which ran forever, on a unknown energy source. What do you think the Press would call it ? ........Yes, a perpetual motion machine.
  2. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    I can't wait until you talk to (your) aliens so they can teach you the LAWS OF THE UNIVERSE and not to blur theorems and prejudices while you finish your perpetual motion machine design. Unknown energy is hard to come by and when you identify the energy source, the perpetual motion machine then becomes a normal non-thermoenergy-law-breaking-machine.
    While I admire your determination in taking the idea of solar roof panels sooooooooooooooooooooooooo far out, I find your logic dizzying. But who knows, it may just inspire someone to build a revolutionary charging roof or new Prius.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    The biggest problem we have in Prii is the first 5 minutes of ICE operation warm-up and low MPG. If the solar power could somehow heat the catalytic converter or something this would benefit all PiP and HEV Prii.
  4. inferno
    inferno Senior Member
    1,072
    405
    Good point there. The Solar Option Prius doesn't do this right? That's just specific for cabin temp?
  5. Mendel Leisk
    42,194
    This is one of my concerns about the Plug-In Prius: the first few minutes when the gas engine starts are going to be rough, lousy mileage and a stone-cold start.
    Our current Prius has the block heater, and it's almost without exception plugged in, for a couple of hours before the first start up of the day. Makes a big difference in warm-up time. Once recently I had to cold-start it, and was surprised at how rough it sounded, for the first minute or so.
    The block heater draws 400 watts, and an hour's use is likely the low limit for decent warm-up.
    Chazz8 likes this.
  6. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I've lived through a complete NY winter now with the PIP (low this past winter was single digit temps with a 3+ ft snow storm thrown in the mix) with my PIP sitting outside 100% of the time exposed to the elements for 14+ hrs between starts. I never even once experienced a rough start up when the ICE kicked in. As a matter of fact- most times the only way I knew the ICE was actually running was to look down at the instantaneous mpg graph and see 50mpg versus 999mpg when running on the EV alone. The PIP still runs on EV battery when it first starts the ICE. From what I've experienced first hand, in the first min or two of ICE startup the ICE is basically idling without providing any motive force to the drivetrain, once it (or the CAT) reaches a certain temp- then it gets connected and actually starts pushing the car- avoiding a rough running period. Even if you try to force the ICE to instantly start up by disengaging the "EV" mode button- the ECU still runs the car on EV untill the ICE can properly warm up.
  7. inferno
    1,072
    405
    You got a PiP in NY and put it on the streets? Or do you just mean NY and NYC. I still would find it hard to believe CityFolk getting a PiP unless their condos/apartments have specific free plugin parking.
  8. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I think the best place for consumer solar panels are on rooftops, not on a car. A panel on your home's rooftop can continually produce electricity. A panel on the car cannot always provide power or usable power.
    3PriusMike likes this.
  9. ny_rob
    1,968
    813
    L.I.- NY
    I live out on Long Island...
    If I lived in NYC proper- I'd probably get an old Checker Marathon battle cruiser to do my bidding on the mean streets :D
    DadofHedgehog likes this.
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Toyota engineers considered using the PHV battery to bring up the catalytic converter temp. They dropped the idea when they found out the amount of energy required. Solar power is much lower than PHV battery can provide.
    It is actually a complete opposite. You can be accelerating (not floored) into highway speed with a cold engine warming up and still see instantaneous 50+ MPG. The PHV battery has 55hp to assist.
  11. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...this thread is for stretch objectives...the OP is going to think of something Toyota missed;)
  12. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    retired4999 likes this.
  13. Dan Cathy
    Dan Cathy Junior Member
    126
    Charging an PiP is like running your hair dryer at "high" for 3 hours. If you're lucky, you may get a full charge in 10 days. That's because you may only get 8 hours of good sun light per day. Here's another problem, the solar panels aren't cheap. You better off invest in a generator powered by wind. I think they are cheaper and produce more power.
  14. Dan Cathy
    126
    Most cold starts happen in the morning when people are going to work. Do you really think the sun is strong enough to heat up anything at 7:00am?
  15. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Nope would need to store in a batt or how about something like an engine block heater but this thing heats up your system parts. Also I was really thinking every time you stop for 5 minutes, the system goes down to 25 MPG if there was a way to hold a little heat in and generate a little heating.
  16. Kit Shah
    Kit Shah Kit Shah
    59
    17
    Roseville, CA
  17. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Runs a bit too close to a syllogism with an undistributed middle:
    Some beliefs widely held to be true in the past have turned out to be wrong
    The laws of thermodynamics are widely held to be true
    Therefore the laws of thermodynamics may well be wrong
  18. Dan Cathy
    126
    I don't know how much this would cost to build, but using induction to charge a car is a better way to go. For example, every time you stop at a light, you get a charge. In the city, they could even put in an entire lane for EV so that they could get power from an induction power source. I have an electric tooth brush that gets its charge from induction.
  19. inferno
    1,072
    405
    That's interesting and very pricey. Sort of like a railway system with induciton - but if that hasn't happened the car thing won't happen in the near future. I vote Solar Panels trickle charge. Yes, you won't get a full charge in a short time but you can gain maybe 10 mpg from the trickle charge of the rotation of the wheels and solar. Look at the NS4 video and trickle charging. I still believe they can achieve at least 10 miles worth of charge parking the car in the sun all day.
    Imagine living in the city, parking your car in the street for the weekends, charging your battery and then you have 10 miles to go around the city. Most efficient application ever.
  20. Dan Cathy
    126
    There's a flaw in your assumption. My wife and I decided to pay a higher premium for a hybrid (Prius) because we want to save money on gas and as a side benefit, it's good for the environment. However, in order to save enough money to justify the higher initial cost, we had to turn the Prius into our main vehicle. We drive the Prius 365 days a year unless we got snowed in or we took the van for vacation. Therefore, if someone is planning to recover the cost of the solar panels and the higher cost of the hybrid, the chances are, the car is not going to be sitting and do nothing on the weekends long enough to get charged.
    From my experience, the technology that sells well is the one that make sense to majority of the consumers.
