RF Wheel Speed Sensor Fault
Discussion in 'Gen 2 Prius Main Forum' started by tugga, Aug 12, 2021.
  1. tugga
    tugga Junior Member
    Mississauga, ON
    Hello everyone,
    I have this 2008 Prius and the ABS lights and the other light with the exclamation mark within a circle (sorry don't know what it means) on the dash were on. My mechanic ran the diagnostic and found that the rf wheel speed sensor was at fault and mentioned that the RF sensor was not reading. To replace this it will cost 300$CAD plus taxes. My question is: I replaced the front tires a year ago, and if this was not done right could this sensor be left out when they replaced the tires? Anything you can provide will be helpful. Thanks,
  2. nancytheprius
    nancytheprius Active Member
    356
    152
    iowa
    Hi if you’re referring the tpms sensor, i had to replace all four of mine (2006 prius) last year! They last 10-15 years. Sams club did them for 35 dollars a tire! hope this helps. editing i just noticed you said wheel speed sensor. Can i delete my post, I’m fairly new to being a more active priuschatter haha?
    iPhone ?
  3. ChapmanF
    15,697
    If the brake warning lights are on, it is likely a wheel speed sensor, not a tire pressure sensor.
    Two of the lights are slightly confusable: the electronically-controlled brake warning looks like a ! in a circle in parentheses, and the tire pressure warning looks almost like that only flatter on the bottom, with a tread. :)
    The wheel speed sensor isn't in the tire; it's mounted to the steering knuckle, pointing at the axle shaft.
    A shop should, of course, rule out a simple wiring issue or sensor mispositioned or with something stuck to it, before jumping to replace it.
  4. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    If you no longer have the "manuals" in the vehicle :
    2007 Toyota Prius Owners Manual and Warranty - Toyota Owners
    2007 Toyota Prius Dashboard Lights & Symbols Guide
    Would jack up the vehicle and check the RF wheel speed sensor, tone ring, and connections before replacing, as it could be an easy fix or connection issue.
    If the tire pressure sensor light just came on, then it is unlikely that it was left out.
    Do you happen to have the thrown OBD2 codes (DTC) that was pulled during diagnostic, as I might be able to provide the factory workup.
  5. doctorman
    doctorman Member
    208
    35
    NY 11020
    what is the Tone Ring?
    had front wheel sensor in a 2009 prius
    the old one read 1.7K ohm
    the 3rd party new replacement read 1.5k ohm
    the issue was intermittent and got worst before replaced
    the old sensor was dirty
    after replacement of the sensor the error came back, did a new ECB yaw sensory reset and learning and drove the car erraticly going fast , stoping short , going fast switch to neutral and stop short after few of those the errors went away on the dash but techstream still was reading the right front sensor error , not sure if that goes away after a while by itself or something else is brewing that will show up again.
    that whole right front does make noises here and there not sure what they might be
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,483
    1,585
    NJ-USA
