Rhino Ramps for Oil Change
Discussion in 'Gen 2 Prius Main Forum' started by jayjohnson, Jan 22, 2005.
  1. ivanbg
    ivanbg Junior Member
    Alexandria VA
    Here are pictures of the constriction of the Power Ramp and the Prius on them.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I made this video a year ago. The timing of my stop was very good. The ramp did not slide at all. If you want to see detail of the construction of the ramp, I'll take pics.
    [ame=http://video.google.com/videoplay?docid=3175183213517953777]Prius: Precise control while driving up a ramp (using electric motor)[/ame]
  3. ivanbg
    Alexandria VA
    If you want to play a prank on someone or scare them, give the car some gas in reverse. I shot the ramps over 6 feet away.
  4. ivanbg
    Alexandria VA
    I have used 2 by 4 to climb up tall curbs and to break the beads of tires.
    Remove Tire
    How long are your 2 by 8 peaces of wood?
  5. khoult
    khoult New Member
    Lexington, MA
    About 2 feet seems to be enough to lift the wheels before the cowling touches the ramp. It does still touch a little bit on the way up, but not enough to matter.
    > How long are your 2 by 8 peaces of wood?[/QUOTE]
  6. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Tsk, that's terribly irresponsible. I always carefully soak up the used oil with a bald eagle.
    Seriously, just about any auto parts or service center in the US will accept used oil.
    cthorsman likes this.
  7. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    please excuse the delay while I pull myself up from the floor ...
  8. Mylar
    Mylar Member
    163
    37
    Cincinnati, OH
    2019 Prius
    I picked up a set of the 8,000 lbs Rhino Ramps at Sears today for $37.26 . They weren't in stock but if you order them from a kiosk inside the Sears store they will ship them to your house for free.
    Now I need to figure out how to get the rear of the car on jack stands using a floor jack and the rear jack point......
  9. turnbowm
    turnbowm Junior Member
    So. Calif.
    I use Rhino Ramps on the front; rear wheels are on the ground. Any reason why you want to jack up the rear?
  10. Mylar
    Mylar Member
    163
    37
    Cincinnati, OH
    2019 Prius
    I'd like to have all 4 wheels off the ground and on jack stands to change the transmission fluid myself in another 3k miles. It also makes rotating the tires easier. I refuse to roll the car up on a ramp, put the front end on jack stands then jack up each rear wheel individually. I feel it puts too much stress on the frame. I'd rather roll the car up onto the Rhino Ramps, use my floor jack to get the front end on jack stands then use the rear jacking point to lift the car and place jack stands on the rear end. Perhaps I just need to spend the $200 - $400 for a quality low profile aluminum floor jack? I was hoping to avoid that....
  11. ski.dive
    ski.dive Active Member
    959
    241
    Hutchinson Island,FL. Mt. Snow,VT
    what size threads is on the prius oil drain plug
    in order to get a drain valve?
  12. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    You totally don't need ramps to do a tranny-fluid change. Unweighting
    the front a little bit [stock jack on one side, maybe your floor
    jack on the other] helps get a little more clearance, but it
    really doesn't have to be way up in the air unless you're
    seriously barrel-chested.
    _H*
  13. Mylar
    Mylar Member
    163
    37
    Cincinnati, OH
    2019 Prius
    I'm more concerned with having the car level so I don't overfill the transmission.
  14. Mike08318
    Mike08318 Junior Member
    New Jersey
    I found that the threads on a bottle of Captain Morgan Long Island iced tea match the oil fill cap. Just cut the bottom of the bottle off, screw on, and you can dump the whole jug in seconds. :)
