Right side control arm removal.??. Gen 3 .2010
Discussion in 'Gen 3 Prius Technical Discussion' started by graham hendren, Dec 12, 2017.
  1. graham hendren
    graham hendren Geeman .. taximan
    82
    NOTTINGHAM ENGLAND. UNITED KINGDOM
    Ok Need to remove the right side control arm . But the front bolt will not pass the oil filter casing. Have read a thread on here they say you need to drop subframe ... Is there another way ? I have jacked the engine block but it's still won't come out it needs maybe 10mm more to pass the oil filter casing . Anyone done this job ????.
    RubberToe AS likes this.
