Right side headlights burn out often??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kobear18, Dec 10, 2018.
  1. kobear18
    kobear18 Junior Member
    92
    23
    san francisco
    Hi every1
    Has any1 experienced this - right side head lights low beam burn out often like 6 months to 9 months. I have used the HID kit and then switched back to halogen but now I still want to switch back to HID because its just shine further and brighter.
    How come its always the right side ? I heard that some lose connectors may cause this ? I need to re-crimping or re-soldering the connectors? Where and how do I do that ? Is there a video? Has any1 tried to fixed this ?
  2. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    The right side is a booger to change. I can see how this results in it being installed without being completely connected. During a routine maintenance my Toyota dealer changed the right low beam. They did connect it solidly but did not get it firmly in the light cover socket. Took me an hour to get that sucker where it should be.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Try LED bulbs
  4. CR94
    CR94 Senior Member
    2,800
    1,231
    Northwestern S.C.
    There was a recall to fix that issue, by adding additional wire to drop the voltage on the bulb. Did you not get it? Mine doesn't seem to be affected, so I've ignored the recall.
  5. tweedle99
    tweedle99 Member
    125
    69
    Round Rock, TX
    I bought a set of beamtech brand from Amazon about a year ago. I switched from HID after a couple of years of use. The cutoff line on the LED bulbs are much cleaner almost the same as halogen.
    RMB likes this.
