Rim specs
Discussion in 'Gen 4 Prius Accessories and Modifications' started by nahh, Oct 24, 2016.
  1. nahh
    nahh Junior Member
    Lithuania
    i'm looking for R16 rims to fit 205/55/R16 tires. What rim specs should I look for?
  2. Archimedes
    Archimedes Junior Member
    70
    45
    Do u know if changing rim size compromises MPG? And by how much?
  3. DeadCannon
    DeadCannon Junior Member
    KY
    16x6.5 or 16x7, probably +35-45 offset
  4. The_edge
    The_edge Junior Member
    Singapore
    Hey Nahh, i've a question, if you're thinking of upsizing to 16in wheels, why not 17in? They will look even better. From my research, upsizing to 17in wheels would require you to get wheels with these specs: 17x7 and an offset of 40.
    I've a Gen 4 Prius and i am going to upsize from 15inchers to 17in wheels when my stock set of tires are due for their replacement.
    However, i am sure your fuel consumption would get worse due to the bigger and thicker wheels and tires...but the improvement in how the prius looks may just be worth this compromise.
    For your consideration, sir!
  5. The_edge
    Singapore
    17x7.5 are also ok. offset should be between 40 to 45.
    hope this info helps
Loading...
