Rim upgrade what tire and why
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Infamous6i9, Jan 18, 2018.
  1. Infamous6i9
    Infamous6i9 Junior Member
    61
    Los Angeles
    I'm planning on going 17s for my prius 17x7 and everyone here says go 215/45r17.. I'm wondering why when I'm doing the computation seems closer to my stock if I went 225/45r17
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Is this on your Gen 3? Or have you changed cars?
  3. Infamous6i9
    61
    Los Angeles
    Oh yea I went 2017 prius 2 on the left.
  4. alanclarkeau
    7,045
    7,593
    Nice - maybe you should change your profile.
    Are you replacing 15"?
    215/45R17 is TOYOTA's stock size which I'd be sticking with. Maybe you risk the wider tyres causing fouling - I'm not sure. Legally, the Speedo MUST read over, and maybe the 225s might become illegal when partly worn.
  5. Infamous6i9
    61
    Los Angeles
    Yup im replacing my 15's. Yea I mean the 225 are on point with the readings. Like .03% compared to the 215 that's why I was a bit confused.. do you guys by any chance know how much the stock 4th gen 15in because I saw a post some guy said it was in the 19lbs range.. my rule when ever I upgrade is to get lighter bigger wheels then stocks that's why
  6. alanclarkeau
    7,045
    7,593
    There was a discussion of wheel mass here:
    How much do stock wheels weigh? | PriusChat
    Infamous6i9 and RCO like this.
  7. Stoweza
    Stoweza Junior Member
    16
    16
    North carolina
    I'm lowered on 18's. I'm using an extremely sticky compound tire, continental contactextreme sport. If you do anything, I would highly advise going with a low rolling resistance tire. I enjoy the cornering and confidence with these tires, but they definitely impact gas mileage on a prius. I went from mid 50's to mid 30's MPG. I don't mind it, but I also have the OEM roof rack which I believe hurt my MPG as well. I also have the full liberty walk kit and Airrex air suspension on the way, so at this point gas mileage has been dismissed. Hahaha
    Colton, Infamous6i9 and krmcg like this.
  8. Infamous6i9
    61
    Los Angeles
    What's the weight of your 18s bro?
  9. Mendel Leisk
    42,343
    The Owner's Manual spec for 17 inch is 215/45R17.
    FWIW, I get similar numbers as you:
    225/45R17 does seem closer, maybe too wide for the rim? Another alternative was 205/50R17, also very close to 15" O.D. They're often rated Extra Load though.
    Infamous6i9 likes this.
  10. Infamous6i9
    61
    Los Angeles
    Yea I might as wellvtake the advice of the owners manual. At least I'll travel more distance and have less milage to show for it
    #10 Infamous6i9, Jan 20, 2018
  11. padroo
    padroo Senior Member
    2,763
    2,253
    I wonder how close the wider tire is to rubbing the suspension?
  12. Infamous6i9
    61
    Los Angeles
    What was the width of the rims, and the tire size
    Depe likes this.
  13. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    Get 205 50 17, less stiff rider and a save you gas, i wish they have 195 tires for 17, don't do believe this rolling BS marketing, thinner tires you get more mpg, and 50 series is closer to the height of the 15"tires than 45 series
    RCO and Infamous6i9 like this.
  14. Mendel Leisk
    42,343
    I've toyed with that (with our 3rd gen with 17") but see a couple of wrinkles:
    1. Seems like all the 205/50R17's are "extra load"? Not sure what that means, stiffer ride?
    2. Costco for one probably won't do it, they're sticklers.
    I like the idea though, all the pluses, and yeah, the Outside Diameter more closely matches the 15".
    RCO likes this.
  15. Infamous6i9
    61
    Los Angeles
    I get what u mean with the 50s instead of the 45. This is my set up riding enkei pf01
    krmcg likes this.
  16. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    The taller the tire more softer ride, my work is all driving related I do 60-70k miles per year driving, if you get 55 series much better it will affect you real mileage on your car, I mean taller tires will gives you a little less mileage you put in your car. Hehe and again less stiffer ride, but careful in your gauge when you are driving 60mph it means you are driving 61-63mph.
    With regards to my last post, don't believe this gas saver tires low rolling BS, the higher thread rating 500+ will give you more miles on tire because it is less sticky on the road due to the rubber being harder, the lower thread rating like 280 on Michelin tires are amazing on braking but I only get 30k miles out of that tire pushing over the limit but you really don't notice the difference on braking, imo you don't need this more sticky on road unless you don't know how to brake and you drive crazy like racing on the street. I found out buying not known brand with 540 thread rating like accelerate phi-r here in Bay area I get them for $230 for set of 4 installed free mount balancing and rotation and repair for 60,000 miles but since I drive in the city I get 50-55,000 miles life on it pushing it to the limit some times less 45,000 because I drive in the city, you can get better miles on it if you don't drive in the city because of turning all the time and making u turn will burn your thread fast, so don't turn the steering wheel when your car is stop, always move a little bit.
    #16 JayLn, Feb 18, 2018
    RCO, Infamous6i9 and Mendel Leisk like this.
  17. Proudowner
    Proudowner Junior Member
    Wurtland,Ky
    Test drove an 18 Prius 2. Loved it, but tire noise is the problem. I guess as quiet as the car is, you're going to hear it. My question, is there a brand tire that is possibly quieter, or last longer than stock tires. Thx for any answers.
  18. Bash4
    Bash4 Junior Member
    16
    Streator IL
    I just kept the stock 15 in tires. I like the softer ride than low profile tires. car.jpg
  19. padroo
    2,763
    2,253
    #19 padroo, Sep 24, 2018
  20. Bash4
    Bash4 Junior Member
    16
    Streator IL
    Mine are Toyo Extensa A/S. They are great on dry pavement. So so on wet. This will be my first winter with car, so hopefully snow traction will be acceptable.
