RIP PiP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by cyclopathic, Nov 26, 2014.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    thanks for the heads up. I am still sitting on the fence with solar.
    As of now we directed costs toward reducing consumption, and it is amazing how much reduction we got from extra 8" of blown in attic insulation, lighter color roof and other small improvements. Looks like we'd need about 28 panels in total, and it would be one slope/0% shade install, so string inverter would be fine for that.
    rxlawdude and lensovet like this.
  2. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    I hear ya. When I had my 1500sf "bachelor pad," I replaced the 1975 HVAC system with a hi SEER system that literally cut summer bills by more than 50%. Then I went on a "no incandescent" campaign and replaced them, and CFLs, with LEDs. That got my average consumption over the past five years to around 300kWh/mo. Of course, the PiP then added about another 100kWh/mo.
    Now that I moved into my wife's newer place, I've been on a mission to improve efficiency: no incandescents, all LEDs (a couple of incandescent 12v landscape lights notwithstanding). That really had minimal impact. Even at 3am, the home is sucking about 350-500W/hr, and this past summer I saw electric consumption peak at (I'm embarrassed to reveal) 1500kWh in summer. That over-$400 bill was the last straw. Even though this place was built in 2003, the A/C unit seems to be horribly inefficient. So, once we get the solar installed (hoping sometime next month), next efficiency steps will be to re-tool the HVAC system with high SEER (>15) components.
    None of this will help the fact that this home has LOTS of windows and French Doors (heat loss/gain) and a koi pond (pump running 16h/day), but my goal is to have every kWh generated from solar be sufficient to power my PiP and a future Elan Muskmobile.
    fortytwok likes this.
  3. cyclopathic
    3,292
    547
    2014 Prius c
    (this should probably be taken out from this thread)
    We did incandescent -> CFL but found that it only matters on ones which are on ;). Replacing ones which only get a few minutes a day doesn't do much.
    Here is our checklist:
    - Check roof insulation; blown-in compresses over the time, so when I got to attic the supposed R-30 was down to ~4", about R-14.
    - Attic fan was gone (we have 2 now, one set at lower temp).
    - Reflective insulation installed btw rafters.
    - light color roof
    - Installing low-E film in several rooms with big solar gain
    - Blinds and curtains. Old fashioned but works
    - balancing cooling/heating system (get vent boosters and programmable Vent-Miser). If temps are balanced, no need to keep thermostat as low/high
    - check A/C. If it has a slow leak, it is probably working way lower than 11-13 SEER.
    - programmable thermostat, and better with air recirculation
    - reprogramming thermostat for "economic" switchpoint from heat pump to NG (45F for our locale)
    - humidifier (for heating season)
    - air tight checks
    Not sure if you live in coastal SoCal (I realize 10mi could make big diff), but from what we've seen in many places alone the coast you could live w/o A/C for most of the time if the attic and solar gains are taken care of.
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Yes, she electrified me. And that's Plugz. (Change to mp3)
  5. lensovet
    2,615
    496
    Burlington, NJ
    How good are the windows? My parents replaced windows with brand new 3-pane ones last year and those are more effective at keeping out outside temperatures than their walls. I suspect a lot of your losses are through walls because most homes in California have zero insulation there.
  6. rxlawdude
    701
    220
    So Calif
    2015 Tesla Model S
    Looking at the hour-by-hour consumption over a one year period and playing around with SQL queries, I doubt the issue is insulation, although that's on my list (just lower down the list) to consider. I think the key is the very low efficiency AC system. We've had days of 50kWh/24 hours consumption during the hottest days last summer. Yeah, that's a lot! Those don't occur during cooler weather, where we can get down to "only" about 20kWh/day.
    Our gas bill for heating, in spite of us having a "California cold snap" (that is, LOW temps almost at freezing and HIGH temps in the high 40s/low 50s) seems reasonable. I'd expect a severe change during cold periods that would mirror electricity use during summer if insulation were the primary culprit.
  7. lensovet
    2,615
    496
    Burlington, NJ
    Well keep in mind that if you've got gas based heating the jump will not be as significant given pricing and efficiency issues.
  8. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    What about solar gain from windows and heat trapped in the attic? My grandmother's house gets terribly warm upstairs in the summer, especially in the rooms under the attic and especially in the room with a west facing window, but the downstairs, which is shaded by an awning, can stay pretty cool in the summer, even with two west facing sliding glass doors and two large windows.
  9. rxlawdude
    701
    220
    So Calif
    2015 Tesla Model S
    Virtually all French doors and almost all windows are either north or east facing, with the garage and well shaded front yard facing south and west. Very little impact from direct sun exposure.
    I've not yet been up to the attic to check, but an attic fan indeed sounds like a cheap improvement that would pay for itself pretty quickly. I'll ask the solar contractor (also a roofing contractor) about doing this as an add-on.
  10. cyclopathic
    3,292
    547
    2014 Prius c
    Check temps in attic during peak load. Also the insulation (or lack of). Attic fan and insulation are usually the easiest and the most effective ways to reduce heat load.
    With respect to A/C inefficiency, that was probably the biggest issue. Not the system design low efficiency (13.5 SEER) but a small undetectable leak which resulted in 20% loss of refrigerant over the course of several years. They were not able to find it, but at least it is getting checked and a few oz added regularly once a year. If you have a contract on system, make sure they come and check pressure on a good hot day good luck.
