Rislone 4720 to keep EGR system clean?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DJLand, Jun 21, 2026.
  1. DJLand
    DJLand Junior Member
    Ontario
    Four Touring
    Hi. I'm a high-KM Gen 2 owner, very satisfied. Spouse would like a newer Prii, preferably a V, but having read earlier here about the probability of EGR/Head gasket problems I was sour on used Gen 3s, mostly now with 150k kms or more. Researching more here and on youtube I think I can handle the cleaning project and am actively looking for a lower KM V.
    Yesterday I met a fellow with a V. He said he had run a Gen II Prius for 575,000 miles and then got his V, which now had 375,000 miles. He drives to from Florida from Ontario and sometimes drives for Uber there. He said he has been putting the Rislone product in regularly (maybe monthly?) and has not had any EGR problems. Sounded a lot easier than the mechanical cleaning if it works. Has anyone on here tried this? It seems like easy way to avoid having to tear the whole intake system apart every 100k km.
    I have read also that the EGR problem is exacerbated by a use pattern of mostly short trips where the engine doesn't run at cruise temperature often enough. This would not be a problem for us as we frequently drive 200+km to our cottage and back and annually have been driving to southern Mexico, 5000 km each way, obviously running at cruising temperature for 50 hours each way over a week or so.
    I guess an experiment could be done by tearing down enough to see and document the EGR pipe state of carbon build-up, running a tank of gas with the Rislone 4720, then looking back in the EGR pipe to see if there was any effect.
    Thanks for any observations.
  2. PriusCamper
    PriusCamper Senior Member
    13,476
    5,441
    Pacific Northwest, USA
    Pour and Pray rarely works but seems as though people use this to turn off a P0420 to pass inspection... Not sure how it does that, but I'd rather go with cleaning and inspecting and an oil catch can instead of this. But if you were to try this for keeping the EGR cleaner I suspect the amount of material in oil catch can would be less, which would prove that it works... Doing direct inspection of EGR would be a more long term and harder effort than just checking what's in an oil catch can.
  3. CR94
    CR94 Senior Member
    2,840
    1,246
    Northwestern S.C.
    Yeah, IF.
    Why or how would that stuff have any effect on the EGR system?
    #3 CR94, Jun 21, 2026
    Brian1954 likes this.
  4. frodoz737
    frodoz737 Top Wrench
    4,811
    2,562
    33
    Snake oil.
    ASRDogman likes this.
  5. Mendel Leisk
    42,379
    Very sceptical, both about the product and driving style, making any difference. 3rd gen EGR was a poor design, prone to clog (to put it politely). See top 3 links in my signature, and the bottom one, for info on cleaning. (On a phone turn it landscape to see signatures)
    douglasjre likes this.
  6. BiomedO1
    BiomedO1 Senior Member
    4,639
    2,434
    Left Coast
    That stuff is a fuel additive; same stuff you get when you buy quality fuel. People can imagine whatever they want; but comparing a gen2 to a gen3 is like comparing apples to oranges - THEY'RE not the same thing. Gen2s don't regularly pop head gaskets.
    IMHO; 5K mile oil changes with full synthetic quality motor oil and an oil catch can; would do more to keep the EGR clean than that gas additive garbage. If you insist on buying a used V; you would need to manually clean the EGR anyways - since you don't know how the previous owners has taken care or not taken care of the car. Also stick to 2015 or newer V's; that's when Toyota quitely made some design changes, to make the motor more reliable and burn less oil.
    Good Luck........
  7. Mendel Leisk
    42,379
    ^Quit using low-friction piston rings, ostensibly to eke out a slightly better mpg stat, but in hindsight prone to oil consumption.
  8. DJLand
    Ontario
    Four Touring
    Thanks for the comments. I understand the skepticism, and largely share it. But the fellow with the old V with 375k miles, claiming he had never had it apart was a pretty good argument for his approach. Just wondered if there was any such experience among you all. That cleaner additive and others mostly claim to be about keeping (I assume carbon) deposits out of the catalytic converter so it is meant to work post-combustion and I could imagine if it works on the catalytic it could reduce carbon in the EGR system as well. How common is it to have a V or Gen 3 with such high milage and no EGR / head gasket issues?
  9. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Well, it could possibly be true. If it's a 2015 or later. Because Toyota updated the pistons
    and rings so you don't have the oil burning issues. So it's not clogging up the egr cooler, or
    the intake egr ports.
    And if he's changing the oil at 5000 miles, and doesn't drive hard, it could be possible.
    But then, it could fail at any time. His car could be running like crap. And he doesn't notice it
    because it has been gradual.
    Is he the original owner? Or the 2nd or 3rd, etc? Someone might have already cleaned the
    egr system and replaced the head gasket.
    And just because "1" person does have an issue, that doesn't make it the norm.
    Remember, even a broken clock is correct twice a day.
  10. rjparker
    rjparker Tu Humilde Sirviente
    11,144
    6,986
    Texas Hill Country
    I could tell you I have never did any work on my 2012 v with 355,000 miles. I would show you the golden oil, clean engine, original cat and accept $10k cash after you marveled at the clean body, interior and functioning electronics.
    I would give you a bill of sale with a line about sold as is and ask for a copy of your drivers license and insurance.
    It would be yours for better or worse.
    It would all be true except for the never had work done. That part would be a lie unless I said I never had to do any work on it (myself). I would certainly sell it for $3k more than it's worth due to the current uncertainty in gas prices amping up buyer fears.
    #10 rjparker, Jun 22, 2026
    douglasjre and BiomedO1 like this.
  11. BiomedO1
    4,639
    2,434
    Left Coast
    What kind of testing has been done to verify what he says is true? You know some people put blocking plates to bypass EGR systems and those engines run fine too. Point is that you don't know; unless you dig into it.
    I would also manually monitor the electric water pump and ECT; since they are known to silently go out after 150K. Waiting for the temperature warning lamp to light up is too late, since it doesn't trip until 248+F - nominal operating temperature for that engine is <200F in 100+F weather with the AC going full blast. You'd think the car is fine running at 245F all day every day; until you blow that head gasket.
    Again; anyone can believe anything they want - It's a free country; but that doesn't make it true.o_O:sleep::whistle:
  12. Mendel Leisk
    42,379
    I suspect there’s at at most only a minor correlation between oil burning engine and EGR clogging: there’s still plenty of carbon in exhaust, without oil burn.
    douglasjre and PriusCamper like this.
  13. Zeppo Shanski
    Zeppo Shanski Active Member
    315
    193
    Chicagoland
    Well ... I'm not telling you to try/use that stuff. I will say however, what the hey, one bottle ant'e gonna hurt anything. I love Rislone products. They sponsored my race team, and we ran regular strait Rislone for that year. Not one problem. I do oil changes on my G2 every 5,000-miles; its got +/- 205,000-laps on it now. 1 of the 4 quarts going is is always Rislone. I don't really believe in voo-doo, but if I was gonna try something I wouldn't have any problem going with a Rislone product.
  14. ASRDogman
    8,070
    4,092
    More or less, I think the same thing. Though, it COULD do damage. Today's engines are
    different then 20-30 years ago.
    It's why I started using valvoline's restore and protect. I figured it couldn't really hurt.
    And if it words, then a bonus for me. But it's not working for me. I've been using in my
    386,000 miles 2010 for the last 10 changes or me. I lost count. It's only $3-4 more per 5 gallon
    container, so I'll keep using it. I see no change in oil consumption.
  15. Zeppo Shanski
    315
    193
    Chicagoland
    Sure ... that's fine. My point was that I've been a fan of Rislone for a long time. I don't think that anything has changed since then. They haven't turned into a sucky company since then either.
  16. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Name your snake oil and my response will always be the same....Snake oil .....
