Road Load HP: 2014 PiP vs. 2014 Prius
Discussion in 'Gen 3 Prius Technical Discussion' started by 70AARCUDA, May 19, 2014.
  1. 70AARCUDA
    70AARCUDA Active Member
    845
    208
    Tucson, AZ
    I was looking at the EPA road-load HP values listed for the 2014 PiP and the 2014 Prius and noticed that, at 50 mph, EPA indicates 8.7 HP for PiP but 9.1 HP for Prius:
    This slight Road Load HP (RLHP) difference really shows up at speeds below 17 mph, as shown by the HP ratio (PiP/P) going above 1.000 (black line; righthand axis):
    telmo744 likes this.
  2. Gas Mizer
    Gas Mizer Member
    149
    46
    Redding, California
    2018 Prius
    So the next time we hit the drags, we should take our standard and not the PiP....
    Wheat State likes this.
  3. 70AARCUDA
    845
    208
    Tucson, AZ
    Honestly, I don't know.
    The EPA PiP test weight is 3500 lbs and the EPA Prius test weight is 3375 lbs, so there's only 125 lbs difference.
    Sorta looks like the PiP needs more HP to get started, but past 17 MPH, it actually needs less HP...up to their max speed of ≈105 MPH, where their RLHP become roughly equal again.
  4. Gas Mizer
    Gas Mizer Member
    149
    46
    Redding, California
    2018 Prius
    Good lord! This car weighs 3400lbs!? A Corvette is lighter! I'm stunned Chevrolet hasn't made that a hybrid yet. All the exotics are heading in that direction.
  5. 70AARCUDA
    845
    208
    Tucson, AZ
    EPA "test" weight is NOT the same as "curb" weight (all fluids fully topped, no cargo or driver). It's basically the mfgr's "estimated" weight of curb+driver+some cargo, ie: a slightly loaded vehicle, but not 100% loaded to maximum capacity.
  6. telmo744
    telmo744 HSD fanatic
    2,011
    651
    Portugal
    I wonder if HV Prius tested has the 17" rims (with 215 tyres) fitted...
  7. 70AARCUDA
    845
    208
    Tucson, AZ
    No, the Toyota document to EPA lists the same P195/65R15 89 AS tires for all three test vehicles (2 base PiP; 1 advance PiP).
  8. telmo744
    2,011
    651
    Portugal
    3 PiP? What about the HV Prius?
  9. 70AARCUDA
    845
    208
    Tucson, AZ
  10. telmo744
    2,011
    651
    Portugal
  11. TomB985
    TomB985 Member
    137
    64
    Isanti, MN
    Of course the PiP is a heavier car, does it ride lower? From what I understand the only two things that can affect road load HP would be aerodynamics and tire rolling resistance. Frictional losses from the wheel bearings should be the same between the two of them.
  12. 70AARCUDA
    845
    208
    Tucson, AZ
    Curiously, that second EPA document shows same 9.1 RLHP @ 50 mph and same ABC-coefficients for both 15" and 17" rims, which to me, indicates Toyota did NOT actually test 17" rims.
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,967
    Fort Lee, NJ
    Well, the rims are different. PiP has a full alloy premium aerodynamic wheels (without covers). Perhaps, they are lighter?
    Is it enough for the 0.4 HP difference?
  14. 70AARCUDA
    845
    208
    Tucson, AZ
    A) Lighter wheels would require LESS power (rotational inertia) to get turning...
    B) Better aerodynamic wheels would create LESS aera drag...
    However, the PiP's higher RLHP below 17 MPH does NOT compute; but, I'm at a loss to explain why.
  15. usbseawolf2000
    14,487
    2,967
    Fort Lee, NJ
    With recent Ford lowering MPG of it's cars, it reminds me of this thread.
    I think we should discuss more about it. Why is PiP's RLHP lower than a regular Prius. PiP's highway MPG is 1 higher. Is it the reason?
  16. 70AARCUDA
    845
    208
    Tucson, AZ
    SWAG on my part, but maybe Toyota has "reprogrammed" the PiP use of EV at < 17 MPH in attempt to "squeeze" more EV time? The consistently lower RLHP > 17 MPH would seem to indicate better aerodynamics, which, respectively, effects drag and HP as squared- and cubic-functions.
Loading...
