Road trip Chicago to Anchorage.
Discussion in 'Prius c Main Forum' started by tgpii, Dec 28, 2015.
  1. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Remote start doesn't work for me because my car's in an enclosed (but unheated) garage. I installed the block heater and I also picked up a cabin heater - I plug both of them in about 30-60 minutes before I plan to leave and the cabin and all its surfaces (like the seat and the steering wheel) are nice and warm and the engine is warm enough that it starts putting out cabin heat almost right away. And a bonus is that I save a little gas because the engine doesn't have to run as long or as often to get up to the temperature required to heat the cabin.
    I'm not driving to Alaska and the temperatures here in Vancouver BC really don't get all that cold - but it sure is addictive to have a nice warm car waiting for you.
  2. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    Spideraman?
    What are the differences between engine block heaters, plug heaters, oil pan heater, batter heaters, trans heater, ect? Factory vs aftermarket. What would you recommend for a 2012 Toyota Prius C two in Anchorage, Alaska? What about timers and engine block heaters? I just got new all season tires on the Prius C. It has 52,222 miles. I might be driving it from Chicago, Illinois to Anchorage, Alaska if I get a certain job. If there are other post on this please let me know! I am going to stay on main roads as possible. Thank you.
    #22 tgpii, Jan 11, 2016
  3. amerc001
    amerc001 Junior Member
    Riverside
    I've driven from Southern California to Colorado Springs during winter a couple years back. Snow is weird, I don't know how you guys deal with it.
    tgpii likes this.
  4. fuzzy1
    10,698
    It helps to have grown up with it as a normal part of life for several months every winter.
    tgpii likes this.
  5. tgpii
    tgpii Member
    382
    63
    I just got done using BASB . . .Big nice person Snow Blower, It really blows!
  6. fuzzy1
    10,698
    We couldn't afford a big one, nor could one of the creek bridges to the house support the weight:
    A regular residential blower isn't meant to clear 7000 feet of road in a useful timeframe.
    A full cross country ski outfit for everyone would have been a lot cheaper than a big blower, and vastly faster than an affordable blower.
  7. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    snow is pretty fun when you want to easily experience your car going sideways =D
    other than that, I'm from CA and don't get how all the idiots in WI drive in the snow...they would all slow down really bad, but instead of opening up the gap between their car in the one ahead, they would close the gap
  8. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Spiderman is a PriusChat member in Anchorage but less active of late...
  9. fuzzy1
    10,698
    That is something I particularly noticed when surprise serious snow hit on a work day that a non-snow-driver was driving the carpool. With highway speeds dropping to 15-ish in the slow lane, the nervous white knuckle driver shrunk the following distance to a half second, instead of expanding it to 4+ seconds that traffic would have allowed.
  10. tgpii
    tgpii Member
    382
    63
    I seen a video of a guy driving a Chevy Aveo from Michigan to Alaska. I figure if an Aveo can do it a Prius C can. I find all kinds of stuff on camping and road tripping in a Prius but not much in a Prius C. I my Prius C and most cars I owned I just tilt the seat back and go to sleep. People have all these weird ways to camp/sleep in a Prius but I need ideas for a Prius C PLEASE ! I am from Chicago area so I have driven on snow and ice!
    Last week I got a new set of all season tires.
  11. tgpii
    tgpii Member
    382
    63
    How much is an engine block heater and how much would a place charge to install it? I think they are $40.00 directly from Toyota. Where do you go to get it installed? I heard you need a timer for a heater any ideas on that?
  12. tgpii
    tgpii Member
    382
    63
    I am worried about starting it over heat in it. In the winter if I start my prius C it turns off because it thinks it is at a stop. However if I put the fan on low it stays on. Anoyne have this issue?
  13. InPriusLove
    InPriusLove Member
    167
    42
    California, US
    2015 Prius c
    I have no experience driving from your area or to Alaska but snow and ice will be, along with ubiquitious Cold temperatures, as you know, be the second issue. For a Prius C you have considerations concerning topography. Our 99 horses do not like upward changes of altitudes. They do not like elobgated climbs, steep climbs, or gradual climbs. I drove mine once up to the high desert of California and it was the opposite you would face in temperature and it was a hilly hazard otherwise. Maybe you could push yours to the floor to keep it going but gas will be used, and for that, do not expect more than 25mpg.
    Check where and how high and how far the hills go up. Down is only a problem if you are on ice.
    Chicago is flat. I agree All-Seasons are fine for city and suburbs. I would not gamble without snows and chains on hand for any hillside driving. Mountain ranges are the trouble spots. Take them only in peak daylight.
    You may use your a/s tires in the city but the trip is going to be a challenge with them. We are in winter. There is nothing all- season about it.
    Driving Distance from Chicago, IL to Anchorage, AK
    Nearly 4000 Miles, and you need to know the length of climbs. Go to AAA and let them help you plan your driving and stays. Truck stops sell cheap overnight lodgings not just to truckers. No frills. Call the service manager at the Anchorage dealer to get his/her advice.
    Now here is a thought. Pay the thousand bucks to load it up on a truck to ship, and take a plane.
    Good luck on the job.
  14. mrpinkie
    mrpinkie Junior Member
    31
    North Carolina
    2015 Prius c
    Any car with an ICE can make the trip. They did them with model Ts back in the day. The best advice would be to plan your route.
    1. Make sure that you stop and get fuel before hitting long gaps without fuel stops
    2. Keep your driving times manageable, meaning dont shoot for 16 hour days
    3. If you have the time look for interesting places to stop along the way, planning ahead helps
    4. get a decent set of tire chains, in an emergency they are helpful but local laws will dictate use and they could damage tires
    5. keep an eye on the weather while driving, you dont want to be left exposed in a bad storm
    6. recruit a road trip buddy, a return plane ticket may be expensive but both of you will have the memories
    7. Have fun, stop and take pictures along the way, eat at local spots and remember its not the destination its the journey
    8. Fill your iPod with music, you can always put games and what not back on once you arrive.
    You have 3600+ mile of new places to see. It will take you some time just to make the drive, it doesnt have to be a mundane job make it an adventure.
