Road Trip over Mountains
Discussion in 'Gen 3 Prius Fuel Economy' started by dorunron, Oct 24, 2014.
  1. lester williams
    227
    68
    mississippi
    OK,, I need a little straightening out here. We also toured all over Colorado this summer and went over 11 passes [ Monarch, Wolf Creek, Loveland, RMNP, etc.] and I used the 86 octane gas which was $.20 more per gallon as I was thinking that the higher octane gas was better for climbing passes. Are y'all saying use the lowest octane???
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    That's what they are saying Lester. I went with the owner's manual. Other's here on this board have ALWAYS said 83 or 85 is fine as long as you are up in the higher elevations.
    Being a flat lander who lives at 80 feet of elevation, we don't have that sort of fuel here... I kind of figured Toyota would say 83 or 85 for high altitude service in the manual, but no word of it.
    So, as I said earlier I will try it next time and see how the Prius runs.
    Peace,
    Ron
    MERGED two back to back posts
    After doing the math, I believe I am mistaken and you are correct.
    It seems that a 1KW inverter hooked up to the 12 volt battery would be pulling about 85 amps at full load if my math is correct. So if I really want 2 KW or higher I am going to have to tie into the traction battery with a different setup. Have seen other's do similar stuff here on PC. For now, I will be content with the 1 KW and see how that works for me. It will either work or pop the circuit breaker on the inverter when I plug in the coffee maker. I can buy a low wattage unit just for that...
    Thanks for the heads up and the reminder. I should know better since I have always been a math whiz.
    Now if I want to be real creative, I could hook up the 2KW inverter to my portable jump start pack. That would at least make the coffee for me. Could charge it up later on with a traditional 120 volt outlet or maybe even the inverter...
    Ron
    #22 dorunron, Nov 4, 2014
  3. lester williams
    227
    68
    mississippi
    OK, thanks Ron, I somehow took from the ''Premium gas'' thread that they would climb hills, passes, better with higher octane. Stupid gas was high $$ enough for the folks in Colorado without paying an extra $.20 - $.30 per gallon. Gulf coast regions will spoil us on gas cost, I guess.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You can go down about 0.5 RON per 1000ft elevation gain. Filling up with 83 up in the mountains is fine for the Prius. Just make sure to fill it up with something higher if that tank will be taking you down to sea level. The 83 that you can get in Summit County at 10,000ft is like 78 when you get to sea level and that's no good.
    dorunron likes this.
  5. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I filled up with Regular throughout our recent trip to Yellowstone, Glacier, Minneapolis, Green Bay and back to Phoenix and didn't have any problems I'm aware of. Where it says 87 in the manual, I assume they simply mean Regular. If it's a potential problem though, I guess I need to find out what octane they use in Flagstaff and avoid filling up there if it's 85 and I'm heading back to Phoenix where it's 87. Since Flagstaff is 130 miles north, I would only use 1/4-1/3 of a tank before getting to Phoenix. I find it hard to believe using the rest of a tank full would do damage, but then I'm not an expert on octane.
  6. dorunron
    3,318
    1,103
    Houston, TX
    I feel the same way Lester. I am used to paying LESS than $3 per gallon since the price of fuel dropped. But even at $3.50 per gallon, the cost was not so extreme that we could not afford to have a great time in a fabulous machine such as the Prius. Already planning another road trip. This time to Ohio to visit my Aunt.
    Ron
  7. dorunron
    3,318
    1,103
    Houston, TX
    Thanks again for the GREAT info. It really does help 2K
    Ron
  8. dorunron
    3,318
    1,103
    Houston, TX
    The whole reason why I chose the 87 and above octane is illustrated by the above post. It is in the manual. Thank God there is Prius Chat to clarify and give additional info. Even though the manual is over 300 pages in length. It still isn't enough information on this fabulous product Toyota has given us to enjoy.
    Peace Everyone,
    Ron
  9. DrDoug
    DrDoug Junior Member
    Salt Lake City, UT
    I do almost the exact opposite route you took, except traveling different roads. We take a trip one or twice a year from Salt Lake City to Dallas. I've traveled most every common route - from taking I-80 East to Cheyenne, South to Denver, East to Salina, then South to Dallas, or heading South from Salt Lake to Moab, South to Monticello Utah, through the 4-corners area, and then through New Mexico and West Texas. I've traveled back home from Dallas up through Salina to Denver, only to find that I-80 was impassable due to weather (we are normally in Texas with family for Thanksgiving or Christmas), so we went west over I-70 into Utah and then home. Most of these trips have been in my TrailBlazer getting a horrible 21 MPG at best. Last Feb, we purchased a package 4, non touring with 130K on it. Slapped some new Ecopias on it and took a spring-time trip with the two kids. To say that we were fully loaded was an understatement, yet going the southern route, netted almost 49 MPG overall. We even had a better than 60 MPG tank going through New Mexico with a tailwind. I definitely feel small in that car compared to the TrailBlazer, and miss the storage, quieter ride, and better view of the road ahead, but the Prius was definitely a nice vehicle. What's amazing is that we spent less for that trip in car expenses, including new tires and fuel, than we normally do for just fuel in the TrailBlazer. With 200K on the clock, and a transmission that is nearing rebuild time, needless to say that the Prius is our first choice vehicle for these trips.
    Utah is definitely pretty country with a wide variety of scenic elements. Glad you had a nice trip.
    Doug
  10. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    Ron, I so agree about the manual. They outline everything, like the displays, nav, etc., but they provide very little in the way of what the data means and how to use it to one's advantage. I think part of the problem is that so much in the manual comes from other vehicles and they've made it easier on themselves to print manuals, but harder for owners to understand just how everything works. We're taking a long weekend/holiday trip to LA (leaving Saturday morning and returning Tuesday evening). I just finished entering all our potential destinations in the Prius. I do this so I can access them while moving because I don't know how to find "Griffith Park Observatory" using voice commands. I get that I can say "Find next McDonald's" or "Find Next Costco" and get a list of each, but I can't say "Find Granny's Restaurant" when in Cody WY and get a destination. Even if I say "Find Next Restaurant" it will not display Granny's even if I'm sitting in front of it or just down the street from it. If I stop, Granny's shows up if I search POIs/Restaurants or enter Name/Granny's. The few examples in the manual for voice commands leave so much to be desired.
    To be fair, I've never used voice commands with my Garmin, so I don't know how limited it is. I get that Toyota doesn't want the driver typing or having to look at the display too long, but it seems so simple to me to just activate every command by saying it. For example, if I press DEST on the display, the next screen of options is displayed. If I use Voice and say "destination", the same thing should happen for that screen and each successive screed. In this case, I should then be able to say "state arizona", "city phoenix", street washington" and "number 123" to enter the address. I should also be able to say "POI" and have that screen come up so I can then step through it with voice commands. That's the way I always thought voice commands worked on any device, but the Prius has shown me how wrong I was. I like that I can say "destination 123 lombardi avenue green bay wisconsin", but I don't understand not being able to say "find granny's restaurant in cody wyoming". I also don't know why I can't set it to display results along my route while the car is moving.
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Also keep in mind that the manual is rarely to inform the customer or help them understand the function of the vehicle. It is to save Toyota money. Whether that be through reduced customer service calls or through fewer litigation suits. If you specify something, you are on the hook for it. Leave it out, or play it safe and you are better off legally.
