Roadsign assist very inaccurate
Discussion in 'Gen 4 Prius Main Forum' started by capnbirdseye, Nov 25, 2016.
  1. capnbirdseye
    capnbirdseye Junior Member
    Worcestershire, England
    Roadsign assist seems very inaccurate and I was relying on this to help avoid a speeding ticket here in UK,
    today I had it show 60 whilst driving in a 40 area, several times it showed 40 when in a 30, The car is a brand new 2 days old 2016 Prius. It can't be dirty sensors on the car as it's in pristine condition so Is this a common fault or does my car need spectacles
  2. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    RSA does not work well at all - I disable it and I never really use it. I usually look at the road, so RSA doesn't really help me also because it does not beep or regulate speed if you are faster than the speed limit it recognises. And considering how bad it is recognising, thank goodness it doesn't.
    It even doesn't understand that stickers of speed limits on trucks are not real speed limits...
  3. dstahre
    dstahre Member
    74
    35
    Cahokia
    Four Touring
    I'm pretty sure it's a GPS database, not a sensor function!
  4. pakitt
    2,173
    1,311
    Colorado
    Not at all - it is a camera image recognition system. This is why it is not working that well. And why it is showing speed limits when there are none on German Highways, reading speed sign stickers on trucks (by law they need to show what are the fastest speed they can travel on highways and regional roads). And not doing a very good job at all ignoring them...
  5. raspy
    raspy Senior Member
    438
    699
    London, UK
    I wouldn't call it a fault but simply the limitations of the technology. Here in London, I find it works very well 90% of the time. There are also speed camera audible alerts if you have the Toyota navigation system. I find the combination of RSA and the audible alerts rather good.
    Data Daedalus likes this.
  6. capnbirdseye
    Thanks for your replies, seems it's a general problem everywhere so I will have to be wary and not rely on it being accurate
    RCO likes this.
  7. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    Mine too keeps getting confused with the speed signs it thinks it's seen. Use the pinch of salt principle!
  8. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    In Europe it actually uses image recognition, and the feature is called RSA (Road Sign Assistance?).
    In the US (and probably Canada) we don't have RSA as an option. Instead we have a speed limit display, based on static data from the navigation database (if equipped) as you suspected.
    dstahre, RCO and krmcg like this.
  9. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    RSA is garbage. It works accurately 20% of the time and 10% of the time it does work it is completely annoying popping up on the HUD.
    RCO likes this.
