Roof molding removal
Discussion in 'Prius c Accessories and Modifications' started by Phishie79, Oct 18, 2025.
  1. Phishie79
    Phishie79 New Member
    Kauai
    2018 Prius c
    2018 Prius C, One
    Has anyone tried to remove the black roof moldings? Trying to decide if its possible to remove and add a Yakima roof rack/crossbars for my SUP.
  2. Leadfoot J. McCoalroller
    8,187
    7,694
    Pennsylvania
    2018 Prius c
    I haven't dug into the details, but there appear to be small removable tabs within those trim rails- at just about the right spots for adding a roof rack.
    I have to wonder if Toyota has anchors meant to attach there? Not sure how you would interface them with a third party roof rack, but if that's possible it may make a tidier solution than removing the entire moldings.
  3. Mendel Leisk
    42,077
    On our Gen 3 hatchback I found it was just a matter of hooking fingernails under the trail edge and off it comes. Good to do periodically, clean out any grit, apply some wax.
    They are a little different though, no where near as wide.
  4. Adam of the Northwest
    Oregon
    2015 Prius c
    My local car wash took off the rear left piece for me!
    As far as racks go, it's pretty cheap to get a qualified shop to permanently mount the base plates to your roof, which is much more stable/safe. I did that, and now I can put my rack on or take it off easily as a single unit and hang it above the car in my garage.
